Meget pen integrert forsterker og cd spiller selges. Kan byttes i annen relevant hifi.
Specifications integrert amp.
Power Output: 2 x 180 watts RMS 8 ohms; 1000 VA power supply/in-4
Harmonic distortion: .0007% @ 0dBr; .070% @-30 dBr
Signal to Noise Ratio: 100dBr
Residual Noise: 20 Hz to 22 kHz 46 uV balanced; 46 uV unbalanced
Input Impedance: 100k (balanced); 50k (unbalanced)
Voltage Gain: 34.4 V (30.7 db) into 8 ohms; 27.1 V (28.7dB) into 4 ohms
Input Sensitivity: 1.0 V rms for 150W into 8 ohms; .9V rms for 150 watts into 4 ohms
Dimensions: 16.2”(W) x 4.3”(D) x 16.9”(H)
Weight: Shipping: 62 lbs.
Price: $6,990.00
CD spiller:
TECHNICAL DATA with AUDIO PRECISION analyser MIMETISM 20.1 CD PLAYER
Output digital S/PDIF , 75 Ω , 0.5 V , RCA AES/EBU , 110 Ω , 2.5 V , XLR Output analog Input Signal 1 KHz sinus @ 16 bit / 44.1 KHz Harmonic Distortion ( THD+N ) - 0.0009 % @ 0 dB FS (Full Scale) - 0.0090 % @ -20 dB FS - 0.0900 % @ -40 dB FS - 0.9000 % @ -60 dB FS Dynamic ( THD+N @ -60 dB FS ) 100 dB Residual noise 20 Hz to 22 KHz unmeasurable AES/EBU, 110 Ω , 5 V , on XLR unbalanced , 2 Vrms , RCA
either balanced , 2 Vrms , XLR
Input signal 1 KHz sinus @ 16 bit / 44.1 KHz
Harmonic Distorsion ( THD+N )
- 0.0012 % @ 0 dB FS
Residual noise 20 Hz to 22 KHz 3.4µV @ 4 Vrms, XLR
Signal to noise ratio 115 dB
Company Information:
Mimetism Audio
Website: www.mimetism.com
Price: $6,990.00
CD spiller:
Mimetism Audio
- Forsendelse
- Avtales nærmere
