2 stk. Meridian DSP5200 høyttalere selges til fordel for oppgradering til DSP8000. Disse er brukt sammen med Meridian 818 og størrelsen har ingenting å si på lyden, hverken lydnivå eller kvalitet.
En trenger egentlig kun en god digital signalkilde (S/PDIF) og koble seg direkte på disse, så har en et veldig bra stereo oppsett viss en ikke har et Meridian DSP produkt fra før.
Disse kan og sendes rundt om i landet, men da må frakt dekkes av eventuell kjøper.
Disse er kjøpt i Juli/August 2012 og fremstår som nye.
Ny pris er ca. 65 000kr.
Ta kontakt om en lurer på noe.
Info:
Performance:
Frequency response in-room within 3dB from 35Hz to over 20kHz. Linear-phase mid/top crossover. Output >108dB spl @ 1m on music material. Noise less than 15dB spl. Overall distortion typically <0.02% at any frequency or level.
Inputs:
Meridian SpeakerLink in and out (RJ45), S/PDIF digital input, 32kHz-96kHz sampling rates at up to 24 bit with MHR support (phono).
Construction:
`2 1/2-way´ acoustic reflex system. Single-port (vertical model) or dual-port (horizontal centre).
Drivers:
2 x 160mm polypropylene bass drivers.
1 x 25mm aluminium-dome tweeter, silver wire, short horn-loaded.
Electronics:
Two precision 24/192 oversampling converters for bass/mid and tweeter signals. Active bass/mid crossover. Digital and conversion electronics constructed using advanced surface-mount techniques and partitioned 6-layer printed-circuit boards.
DSP:
150MIPS digital signal processor. Digital crossover at 2.6kHz. Response correction for the whole system. Bass protection. User tone controls. Analogue/digital volume and phase control.
Amplifiers:
Three 75W power amplifiers, one for each driver.
Display:
Eight-character display with system lights, can be blanked.
Dimensions:
Vertical model: height: 903mm (without spikes/feet); width: 300mm at base, tapering to 179mm; depth: 356mm at base, tapering to 217mm.
Horizontal centre model: height 200mm; width 734mm; depth: 265.75mm at deepest point.
Weight:
35kg packed
Info:
Performance:
Inputs:
Construction:
Drivers:
Electronics:
DSP:
Amplifiers:
Display:
Dimensions:
Weight:
35kg packed
