Selger denne. Fungerer utmerket og i topp kosmetisk stand. Med spikes. Har originalforpakning.
Kan hentes i Oslo. Ev. sendes for mottakers regning og risiko.
Frequency Response | 20–120 Hz ±3dB; Anechoic through LFE effects input |
Impedance | Line level RCA: 20,000 Ohms Compatible with 4, 6, or 8 Ohm rated amplifiers. |
Low Frequency Transducer | Three 8" (20.3cm) high excursion, aluminum cone with extended throw drive assembly, sealed non-resonant asymmetrical chamber format |
Amplifier | 350W (at less than 0.5% THD) 900W (peak) |
Audio Controls | ±10dB at 25Hz |
High Pass Filter Frequency | Bypass, 40Hz, 70Hz |
Low Pass Filter Frequency | 30, 35, 45, 55, 65, 80Hz |
Inputs | Left/Right RCA Line Level, RCA LFE, Speaker Level |
Power Draw | Max: 300 Watts Idle: 15 Watts Standby: 10 Watts |
Weight | 70 lbs. (31.8 kg) |
Dimensions | 17.9" x 17.1" x 16.5 " (45.4cm x 43.5cm x 41.8cm) |
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
