Eksklusivt utseende med oppløst og nyansert lydbilde. God på musikk. Internettradio og musikkstreaming over nett. 6 HDMI inn og 2 ut, v1.4a. Pre-ut for alle kanaler.
Receiveren er strøken. Fjernkontroll, målemikrofon og strømkabel følger med.
Kan sendes i uoriginal emballasje.
Hjemmeside: http://us.marantz.com/us/Products/Pages/ProductDetails.aspx?CatId=AVReceivers&SubCatId=0&ProductId=SR7005
Omtaler:
https://www.soundandvision.com/content/marantz-sr7005-av-receiver
http://www.lydogbilde.no/test/hi-fi/test-av-fem-3d-klare-surroundreceivere/marantz-sr7005
SPESIFIKASJONER:
MULTI CHANNEL/SURROUND
Number of Channels 7ch Amp. 7.1ch Processing
DTS HD Master&High Res. Audio/ES/96/24/Discrete & Matrix6.1 /Neo:6/Express
Dolby True HD/Digital Plus&EX/ Pro Logic IIz, IIx, II/Virtual Speaker/ Headphone
NEURAL yes
SOUND ENHANCEMENTS
Current Feedback Topology Preamplifier Stage
Discrete Amplification Yes
Power Transformer EI
D/A Conversion 192kHz/24-bit
Digital Signal Processing ANALOG DEVICES: SHARC 32-bit
Video Off (Pure Direct) Yes
Source Direct Yes
Chassis Steel
Variable X-over Yes
Display Off Yes
Video Up-conversion Composite/Component to HDMI, Composite to Component, HDMI to HDMI
Auto Calibration by MIC Audyssey MultEQ XT
Satellite Radio Ready Sirius
AM/FM Tuner 1
Bass Redirection Yes
Lip-sync (digital audio delay) Yes
Software Upgradable Through Internet
IN-/OUTPUTS
VIDEO
HDMI In 6 (Including Front input: 1)
Component In 4
S-Video In 0
Composite In 5 (Including Front input: 1)
HDMI Out 2 (Select one output)
Component Out 2
S-Video Out 0
Composite Out 2
AUDIO
Analog L&R In 7 (Including Front AUX1)
Analog L&R Out 2
Digital Optical In 3 (Including Front: 1)
Digital Coaxial In 2
Digital Optical Out 1
Digital Coaxial Out 0
Other Front USB input: 1
OTHER
Pre-Amplifier Out 7.1ch + 2nd Subwoofer out: 1
Multi-Channel In 7.1ch
Multi-Room Audio Out Zone 2 Pre out, Zone 3 Pre out
Multi-Room Video Out Zone2: Component: 1, Composite: 1
Multi-Room Speaker Out Assignable Surround Back L/R speakers as for Zone 2 or 3
Speaker A/B Yes
Networking DLNA 1.5 cirtified Audio/Photo Streaming, Internet Radio, Streaming service capability(Rhapsody/Napster/Pandora/flickr)
External control RS-232C, Web Browser Control, IP Control
DC Triggers 2 (12V, 150mA)
D-Bus Remote (RC-5) In/Out 1/1
Flasher In/IR Receiver In/Emitter out 1 / 0 / 0
Front Panel A/V Inputs USB: 1, HDMI: 1, Digital Optical: 1, Video: 1, Analog L/R: 1
Headphone Out 1
SPECIFICATIONS
AUDIO SECTION
Power Output 125W (20Hz - 20kHz, 0.08% THD, 2ch driven) x7
S/N Ratio Analog: 96dB (IHF-A weighted, Direct Mode), Digital: 102dB
Freq. Response (Analog In) 10Hz - 100kHz (+1/-3dB, Direct Mode)
TUNER SECTION FM
Frequency Range 87.5 - 107.9MHz
S/N Ratio (Mono/Stereo) 78 / 68 dB, HD: 85dB
TUNER SECTION AM
Frequency Range 530 - 1710kHz
S/N Ratio HD: 85dB
VIDEO SECTION
Video Freq. Response (Component) 5Hz - 60MHz (+0, -3dB)
Video Freq. Response (Composit, S-Video) 5Hz - 10MHz (+1, -3dB)
GENERAL
Color Black
Front Panel Aluminum/Glass-resinforced resin
Remote Control Backlit, LCD, Learning, Pre-code System Remote Controller
Power Requirement AC120V 60Hz
Power Consumption 700W (Standby: 0.2W, CEC available Standby: 0.4W
Dimensions W x H x D (Inchs) 17-3/8" x 7-6/16" x 16"
Weight (lbs) 28.7
Omtaler:
SPESIFIKASJONER:
NEURAL yes
SOUND ENHANCEMENTS
Source Direct Yes
Chassis Steel
Variable X-over Yes
Display Off Yes
AM/FM Tuner 1
IN-/OUTPUTS
VIDEO
Component In 4
S-Video In 0
Component Out 2
S-Video Out 0
Composite Out 2
AUDIO
Analog L&R Out 2
OTHER
Speaker A/B Yes
Headphone Out 1
SPECIFICATIONS
AUDIO SECTION
TUNER SECTION FM
TUNER SECTION AM
S/N Ratio HD: 85dB
VIDEO SECTION
GENERAL
Color Black
Weight (lbs) 28.7
