Larsen høyttalere har ett unikt design. De er lette å plassere og har en fyldig lyd. Høyttalerene kan høres i Moet Audio sine lokaler i Stavanger. Pris avhengig av utførelse.
Test: https://www.theabsolutesound.com/articles/larsen-model-62-loudspeaker/
For its size, the Larsen 6.2 is a definite overachiever when it comes to bass output and dynamics that won’t leave most listeners uninvolved—whether with late-Romantic symphonic repertoire or energetic pop and rock. If you’re going for realistic dB levels with Boris Godunov or Daft Punk, you’re going to be disappointed. For many, though, the 6.2s will effectively transmit the power and excitement of large-scale music of all sorts because of all the things it does so well. What we have in the Larsen 6.2 and other Larsen models is the full realization of a decades-long effort to understand the behavior of real rooms and to leverage those observations in the design of a loudspeaker that will play music with a minimum of coloration and distortion. If your loudspeaker budget is anything up to $5k, the Larsen 6.2 deserves a very, very long listen.
Test: https://novohighend.com/larsen-model-6-2-loudspeaker-review/
Having Larsen 6.2 speakers in my system for the past few months provided me with hours and hours of music enjoyment. Throughout my listening tests, they performed extremely well and were up to the challenge with any style of music, from jazz to classical to progressive metal. With their laid-back, very natural, balanced and spacious sound, they can complement any high-end or even mid-range audio system. Thanks to their unique design and sound characteristics, they can be considered a lifestyle product, suitable not only for audiophiles, but for anyone looking to enjoy quality music reproduction in their home without sacrificing aesthetics and living space.
Fra produsenten:
At the time when Larsen 6 was under development, we understood that this should be “the-value-for-money-speaker”.
We boosted the components and made some strategical changes. And yes, several reviewers noticed this. All the good qualities from Larsen 4 was brought to a higher level and still with a small footprint and placement flush against the wall. The 3D-sound stage turned out sharper and more distinct. In this 2 way system you have the same bass element and tweeter as in Larsen 8 so we dare promise the value for money.
Larsen 6 employs trickle-down design and technology in a timeless and compact design – creating a muscular, neutral and amazing three-dimensional sound stage for serious audiophiles to enjoy.
The upgraded version Larsen 6.2 has got a new tweeter the same as in Larsen 8. It was done 2010 so a vast majority of you listening to L 6 today do have this tweeter.
Effect 100 W
Sensitivity 88 db
Impedance 8 ohm
Bass driver 177 mm
Width 230 mm
Height 750 mm
Depth 260 mm
Weight 12,5 kg
Fra produsenten:
Effect 100 W
Sensitivity 88 db
Impedance 8 ohm
Bass driver 177 mm
Width 230 mm
Height 750 mm
Depth 260 mm
Weight 12,5 kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
