Larsen høyttalere har ett unikt design. De er lette å plassere og har en fyldig lyd. Høyttalerene kan høres i Moet Audio sine lokaler i Stavanger. Leveres i sort, hvitt og valnøtt.
Fra produsenten:
Larsen 4 is still, after more than ten years on the market, the first relation with floor standing ortho acoustic speakers for many people. You get a warm tonality, a big sound spectrum from 28 Hz bass to what your ears can take from this 2 way system with a very small footprint.
With a pair of Larsen 4, you have no need for a separate subwoofer or an exactly calculated sweet spot. Like all other Larsen ortho acoustic speakers they are very easy to furnish. You just put them discreetly close to the wall and they fill the room with your favorite music from your favorite source.
Let the upgraded version Larsen 4.3 (2021) be your first step into the ortho acoustic world. We are sure you will find all the advantages with a pair of Larsen in your living room.
Larsen version 4.3
Larsen version 4.3 was introduced in March 2021, after gone through an internal makeover. Two new drivers from the Danish company SB Acoustics and a new crossover brought the speaker to a new level. SB Acoustics have succeeded to improve their drivers in a way that agrees well with Larsen’s ortho acoustic philosophy and wishes.
What will you get with Larsen 4.3?
“A real audience-friendly bass and a much better discant is what we achieved”, says John Larsen.
“The new Larsen 4.3 has the same deep bass response, but noticeable lower distortion in the midrange and high frequency range. This manifests in an airier soundstage, not harsh at all, where you more easily can distinguish and follow details, as well as the core of the general presentation of the musical performance”, says Stefan Björklund, our Technical Advisor.
Effect 100 W
Sensitivity 87 db
Impedance 4 ohm
Bass driver 174 mm
Width 230 mm
Height 735 mm
Depth 260 mm
Weight
11,5 kg
Fra produsenten:
Larsen version 4.3
Effect 100 W
Sensitivity 87 db
Impedance 4 ohm
Bass driver 174 mm
Width 230 mm
Height 735 mm
Depth 260 mm
Weight
11,5 kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
