Butikk Kudos Cardea Super 20A i Demo
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 68.400
Annonse beskrivelse
Annonse nummer: 225922
Ring for demo og tilbud
The Kudos brand was launched with the Cardea series, and the Super 20A is the topmost development of the series. Think of the last time you met somebody who was so fascinating, so entertaining and so utterly engaging, and who had a voice so captivating, that you could happily listen to them forever. That is the feeling you get on meeting a Cardea Super 20A. In short, it is a brilliant communicator and it knows how to hold a room. It is also incredibly insightful, probing into the depths of each recorded musical performance in order to faithfully expose everything that is in there.
The sense of occasion was electric, like being hard-wired into the original performance with so much texture and detail, fiery virtuosity, and drama, says Hi-Fi Plus magazine. Beautifully clear, open and lively, revealing every last layer of fine micro detail.Deliciously authentic, adds Hi-Fi News. It is a loudspeaker that is indeed a little bit special.
Les bare hva Håkon Rognlien i Fidelity skriver "...Kudos Cardea C20 Super er faktisk en smått fantastisk høyttaler. For 42500,- kan du altså få en høyttaler med egenskaper i verdensklasse, så som:
- Fantastisk diskantoppløsning fra ett av verdens beste diskantelementer
- Romstørrelse og plasseringsevne helt på høyde med de beste høyttalere som kan kjøpes for penger
- Klangstruktur og presisjon som ikke overgås av mange høyttalere uansett pris......."
Type: 2 way, Bass Reflex
Recommended Amplifier Power: 25W ? 300W
Sensitivity: 88 dB
Nominal Impedance: 8 ohms
Frequency range:30Hz ? 30kHz ?AIRR? (Average In Room Response)
Tweeter:29mm Kudos Crescendo K2
Dimensions: 925mm x 200mm x 270mm (hwd)
Finishes: Black oak, cherry, oak, walnut, rosenut, satin white
Test:
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
