Selger min Graaf GM 20 OTL forsterker.
Følger med bunnplate med kjølevifte i, og batteri til å drive viften med. Orginal bunnplate følger også med.
Kan høres hos meg i Arendal.
Selges kr 20000.-
SPECIFICATIONS
Function: OTL/OCL Tube Power Amplifier
Output Power: 20+20 W RMS [Stereo], 65 W RMS [Mono]
Output Impedance: 8 - 16 Ω , 4 - 16 Ω [Mono]
Input Sensitivity: 600 mV
Input Impedance: 50 K Ω
Total Harmonic Distortion: 0.4% at 1W
Signal-to- Noise Ratio: unweighted 85 dB, weighted 95 dB A
CMRR: 60 dB
Frequency Response: 1 Hz to 350 KHz (-3 dB)
Rise Time: 1 µsec.
Damping Factor: 4
Negative Feedback: 6 dB
Using tubes: 6922 x 2; EF-184 x 4; 6C33C x 4
Power Supply: 120/220 V, 50/60 Hz
Power Dissipation: 450 W
Dimensions (W x H x D): 350 mm x 215 mm x 440 mm
Weight: 22 Kg
Selges kr 20000.-
SPECIFICATIONS
CMRR: 60 dB
Rise Time: 1 µsec.
Damping Factor: 4
Weight: 22 Kg
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
