Super fleksibel og meget vellydende hybrid strømforsyning demobrukt.
Som ny med emballasje. 5.5/2.1 og 5.5/2.5 dc kabel medfølger.
Selges kr. 8990,-, veil 14089,-
Leverer nok strøm til å drive kraftige hodetelefonforsterkere, dacer, streamere, routere, RIAA trinn, platespillere osv.
Produktinfo
Test 6moons
Produktinfo
Test 6moons
- Power input:
100-240Vac/50-60Hz (EU/US Version)
90 – 110Vac/50-60Hz (JP Version)
IEC C14 power inlet, a fuse holder with power on/off switch plus two-stage EMI filter for low impedance load with better noise attenuation in low frequency applications - Mains cable: US/EU/UK
- DC OUT cable:5×2.5mm DC plug / 5×2.1mm DC plug
Custom cables made to order at additional cost - Output Voltage Range: 5-30 [V]
- Max Continuous Output Current (for V_out below 10V): 6 [A]
- Max Continuous Output Current (for V_out higher than 10V): l_out= 60[W] / DCout[V]
- Max Continuous Output Power (for V_out below 10V): P_out = V_out[V] * 6[A]
- Max Continuous Output Power (for V_out higher than 10V): 60W
- Dimensions (without knob, feet and connectors) (W x D x H , mm / inches): 217.5 x 206.5 x 50.0 / 8.6 x 8.1 x 2.0
- Net weight (kg / lb): ~ 2,8 / ~ 6.2
- Primary winding fuse: IEC 5x20mm fuse, 3.15AT, 250V
- Secondary winding fuse: Littelfuse 154004T, 4A
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
