Høy waf, høy lyd, høy kvalitet, høyhøyhøy. Fascinerende lyd, med tanke på størrelse og prisklasse. Perfekt til enten stereo eller hjemmekino. Vi har hele serien tigjengelig! Bør oppleves! Kom innom for demo!
https://www.moetaudio.com/produkt/h...e-technology/definitive-technology-demand-d17
Clear, Precise Highs
The D17 couples a laterally offset 1” Aluminum Dome Tweeter with our 20/20 Wave Alignment Lens™. We offset the tweeters by 5°, minimizing wave cancellations off the front baffle to deliver a more precise center stereo image and ensure clear, exacting high-frequency performance and detailed soundstage.
Dual 10" Passive Bass Radiators for visceral bass response
Twin integrated 8” passive bass radiators in each speaker produce extraordinary low-end extension for louder, lower, unforgettably clean bass performance.
Audiophile-Quality Crossovers for beautifully balanced audio
Demand Series crossovers are built with the latest premium audiophile-quality parts, including polypropylene metal-film capacitors and air-core inductors. These high-end components meticulously manage frequencies for clean and crystalline treble, refined and articulate midrange, and linear, low-distortion bass. This ensures that every detail comes through within a clear, balanced presentation that never sacrifices power.
HIGH-PERFORMANCE TOWER SPEAKER
Qty Included | 1 |
Orientation | Vertical |
Height | 43.25" (109.86 cm) |
Width | 10.17" (25.83 cm) |
Depth | 14.72" (37.39 cm) |
Weight | 64 lbs (29.03 kg) |
Driver Enclosure Type | MDF cabinet with extruded natural bead-blasted aluminum front baffle |
Driver Complement | • (1) 1" (2.54 cm) d (Round) Annealed Aluminum Dome and Laterally Offset - Tweeter • (1) 6.5" (16.51 cm) d (Round) Polypropylene BDSS Bass - Midrange • (2) 6.5" (16.51 cm) d (Round) Carbonfiber Woofer - Mid/Woofer • (2) 10" (25.4 cm) d (Round) Side-firing, passive - Bass Radiator |
Total Frequency Response | 38 Hz → 24,000 Hz |
Nominal Impedance | 8 ohms |
Sensitivity (1 watt @ 1 meter) | 87 dB |
Lower and Upper -3dB Limits | 42 Hz → 22,000 Hz |
Audio Inputs | |
Speaker Inputs | (1) (Set) 5-Way Binding Posts - Gold-Plated |
Recommended Amplifier Power Per Channel | 40 watts → 300 watts |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
