Demobrukt Auralic Aries Mini selges. Svart. Strøken. Går som ei klokke og blir stadig forbedret med bra oppdateringer.
Streaming Services
Local uPnP/DLNA library content
TIDAL, Qobuz and WiMP online streaming
Internet Radio
AirPlay, Songcast and Bluetooth
USB hard drive files
Optional internal HDD/SSD
Supported File Types
AAC, AIFF, ALAC, APE, DIFF, DSF, FLAC,
MP3, OGG, WAV, WV and WMA
Sampling Rates
PCM in 44.1Khz - 384Khz at 16 - 32bits
DSD64, DSD128, DSD256
Control Software
AURALiC Lightning DS
OpenHome compatible software
Media Server Compatibility
Built-in Lightning Server
Minimserver, Twonky, Asset UPnP, JRiver
DLNA/uPNP compatible server software
Input
RJ45 Gigabit Ethernet
Dual-Band WiFi connection
USB 2.0 High-Speed for external disk
Output
USB 2.0 High-Speed for compatible DAC**
Coaxial, TOSLINK***
Power Consumption
Playback: 10W at max.
Dimension
Appox. 5.3"W x 5.3"D x 1.1"H (13.5cm x 13.5cm x 2.8cm)
Weight
1.1 pounds (0.5kg)
** 'compatible DAC' means a DAC do not require a driver for Mac OS X
*** Sampling rate limited to 44.1K - 192K only
All specifications are subject to change without notice.
Streaming Services
Internet Radio
Sampling Rates
Control Software
Input
Output
Coaxial, TOSLINK***
Power Consumption
Dimension
Weight
1.1 pounds (0.5kg)
