Sjelden Audiolab 8000PPA phono mm/mc. Noen bruksmerker etter mange år men en flott riaa i god stand. Selges kr.3900,- inkl. frakt. Foretrekker Vipps eller til konto. Har ikke org. emb men pakker svært godt og sender for kjøpers risiko.
Da jeg avslutter hobbyen har jeg også en 8000Q preamp i god stand for salg.
Henv. PM
Mvh. Morten
Se manual og specs på: https://www.hifix.co.uk/brochures/107203.pdf
Specifications 8000PPA
Input Level
(at 1 Khz)
Input Impedance
(at 1 kHz)
Gain (at 1 kHz)
(Rear switch set to 0dB)
Max. Input Level
(at 1 kHz)
Audio Output
Impedance
Maximum Audio
Output Level
Signal to Noise Ratio
Frequency Response
(-3db)
Frequency Response
(10 Hz ?- 20 kHz)
Total Harmonic and
Intermodulation
Distortion + Noise
Channel Separation
Channel Balance
Low Frequency
IEC Filter
Bandpass Filter
Operating
Temperature Range
AC Supply Voltage
Power Consumption
Dimensions
Overall (WxHxD)
mm
mc 58
mc 68
mm
mc 58
mc 68
mm
mc 58
mc 68
mm
mc 58
mc 68
50 ? nominal
11 V rms at 1 kHz
greater than 75 dB (relative to 0.5 V rms output)
mm
mc 58
mc 68
± 0.2 dB
2.2 mV (rel. 175 mV rms output)
220 µV (rel. to 175 mV rms output)
75 µV (rel. to 175 mV rms output)
47 k?, 100 pF nominal
470 ?, 3.3 nF nominal
38 dB
58 dB
68 dB
140 mV (+29 dB rel. to 5.0 mV)
14 mV (+29 dB rel. to 0.5 mV)
4.7 mV (+33 dB rel. to 0.1 mV)
0.1 Hz ? 60 kHz
0.3 Hz ? 60 kHz
1 Hz ? 60 kHz
mm
mc
mm
mc
± 1 dB (1.5 dB with bandpass filter)
?3 dB at 20 Hz, 6 dB / octave slope
?3 dB at 40 Hz and 20 kHz; 12 dB / octave slope
10 ? 35 °C
110 ? 120 V or 220 ? 240 V
The voltage is marked on the rear of the unit
less than 25 W
445x74x335 mm - inc. feet, terminals and controls
Henv. PM
Mvh. Morten
Input Level
(at 1 Khz)
Input Impedance
(at 1 kHz)
Gain (at 1 kHz)
Max. Input Level
(at 1 kHz)
Audio Output
Impedance
Maximum Audio
Output Level
Frequency Response
(-3db)
Frequency Response
(10 Hz ?- 20 kHz)
Total Harmonic and
Intermodulation
Distortion + Noise
Channel Separation
Channel Balance
Low Frequency
IEC Filter
Bandpass Filter
Operating
Temperature Range
AC Supply Voltage
Power Consumption
Dimensions
Overall (WxHxD)
mm
mc 58
mc 68
mm
mc 58
mc 68
mm
mc 58
mc 68
mm
mc 58
mc 68
50 ? nominal
11 V rms at 1 kHz
mm
mc 58
mc 68
± 0.2 dB
38 dB
58 dB
68 dB
0.1 Hz ? 60 kHz
0.3 Hz ? 60 kHz
1 Hz ? 60 kHz
mm
mc
mm
mc
10 ? 35 °C
less than 25 W
