Selger Arcam CD 73 pga. oppgradering. Stilren, kritikerrost og vellydende 24bit 192kHz spiller\drivverk.
http://forum.audiogon.com/cgi-bin/frr.pl?rdgtl&1110736579&&&/Arcam-CD-73-CD-Player-
http://www.techradar.com/reviews/au...rs-and-recorders/arcam-diva-cd73-95159/review
If the sonic performance of the CD73 is generous for the price, its measurements are outrageous. In almost every respect, it's pretty much state-of-the-art for CD replay and, indeed, at the edge of reliable measurement. Take distortion: worst-case figures of around 0.001% would be perfectly respectable for any high-priced exotica, as would the absence of any detectable signal-related distortion below about -20dB. Jitter is at or below the measurement threshold of about 120ps, and noise only a couple of dB worse than the very best figures we've seen.
http://www.hometheaterhifi.com/volume_11_2/arcam-diva-cd73t-6-2004.html
Conclusions
Frakt tilkommer med 150kr. Se mine referanser. God Wireworld RCA følger ved henting.
Conclusions
In the end, while I would recommend using the CD73T?s internal DAC, it is certainly nice to know that it also makes a great transport, certainly better than the typical DVD player. The ability to experiment is a pleasing surprise and that flexibility simply adds value to what I already consider an outstanding bargain.
[h=2]Technical Specifications[/h]- Wolfson WM8740 24bit 192kHz Stereo multi-bit sigma delta DAC for superb linearity and low distortion
- DC coupled output with servo control for deep and controlled bass response
- 4th order Bessel output filter delivers detailed and smooth treble
- Dual Layer PCB allows improved grounding and shorter signal paths
- Custom Installation friendly design with rear panel IR control input, 12v trigger input and discrete IR commands for standby, program, repeat, display etc.
- Two pairs of gold plated RCA (phono) audio outputs
- Audiophile grade decoupling capacitors (Nichicon Fine Gold)
- Low dissipation factor polypropylene capacitors in the output filters (WIMA)
- Toroidal power transformer with independently regulated analogue and digital power supplies
- Coaxial SPDIF and Toslink optical digital outputs
- CD Text support
- Compatible with most CD-R and CD-RW discs
- Rear panel switch control for 230v / 115v operation
- Remote control included
- Upgrade path available to CD82T or CD93T specification
