kasol
Acoustic Solid Machine Small u/arm
Denne annonsen er utgått.
Platespilllere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 15.500
Annonse beskrivelse
Annonse nummer: 246565
Acoustic Solid Machine Small. Har orginal emballasje og kvitteringer. Kjøpt i sommer 2018. Solid weight medfølger også. Spilleren befinner seg i Stavanger. Pendler Tønsberg - Stavanger og kan levere på Østlandet også. Arm/Pick up og platerspiller hylle på bilde medfølger ikke.
Solid Machine Small
Solid Machine Small
The Acoustic Solid Machine Small is the entry-level product for our Machine range and is a simplified version our Acoustic Solid Machine model. Despite this, no compromises have been made in the key areas, including the use of our own high-precision «zero tolerance» bearing and a heavy 50mm thick aluminium platter to smooth out residual motor cogging. Nor have any compromises been made on build quality. This is after all a German product. Instead of the decoupled outrigger type feet used on its larger brother, the Machine Small uses three independently adjustable spikes. Felt backed casters are provided to allow the turntable to be used on fragile surfaces. The Acoustic Solid Machine Small can be upgraded to add features from models higher up the range.
One should not underestimate this turntable. The Acoustic Solid Machine Small will extract bass from your records with a surprising degree of depth and clarity. The mid-range transparency, rhythmic integrity and overall musicality are excellent and these are all key to the enjoyment of high quality analogue playback.
Platter:50 mm thick aluminium machined from a single billet
Mat:Natural leather with a 3mm thick acrylic layer
Motor type:Synchronous
Control:Microprocessor controlled power supply
Drive:String-drive by a separately housed motor
Chassis:25 mm strong aluminum body
Dimensions:310 x 310 mm; 200 mm
Weight:Approx 27 kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
kasol
Torget karakterer
Vurderinger (4)
