Accuphase A-36 Class A Stereo Power Amplifier
Accuphase A-36 Class A Stereo Power Amplifier selges. Nypris 74000,-
Dette er en vurderes solgt annonse. Har lyst å prøve et annet oppsett om jeg får solgt fordelaktig, men det sitter langt inne.
◆Instrumentation amplifier" configuration power amplifier The entire power amplifier, including the signal input stage, is configured as a balanced amplifier to achieve balanced signal transmission from the input terminal to the output stage. This provides superior performance in terms of noise rejection and low distortion, as well as resistance to changes in the surrounding environment, further improving the stability and reliability of the power amplifier.
◆Further advanced "MCS+" circuitry The power amplifier section is equipped with the "MCS+" circuit, which is a further developed version of the Accuphase original MCS circuit that improves various characteristics by connecting identical circuits in parallel. The MCS+ circuit improves the stability of the circuit and realizes further noise reduction.
◆Power MOSFETs and 3-parallel push-pull power units guarantee 120W/2 ohms, 60W/4 ohms, and 30W/8 ohms per channel linear power. Large heat sinks are provided to handle the heat generated by Class-A operation, resulting in a high output power of 150W/ch (limited to music signals), even in a 1Ω ultra-low impedance speaker system, with sufficient margin in the design.
◆Current feedback" amplification circuitry for superior high-frequency phase characteristics and sound quality The "current feedback" amplifier circuit returns the output signal in the form of electric current. The "current feedback" amplification circuit provides a natural energy response in terms of sound quality and excellent dynamic characteristics such as rise time. Balanced input for low susceptibility to external inductive noise. Instrumentation amplifier gain control reduces residual noise. Upgradable to 300W/2 ohms (music signal), 240W/4 ohms, or 120W/8 ohms monophonic amplifier with bridge connection Phase selector switch on the rear panel Damping factor: 400 Semiconductor (MOSFET) switch for protection Powerful power supply with large power transformer and large filter capacitors Analog power meter Two sets of large speaker terminals for "Y-Lug" or "Banana Plug" insertion. Bi-wiring connection using speaker terminals A/B Bridge connections can be made by switching the "OPERATION" switch to the "BRIDGE" position. Bi-amp connection can be made by switching the "OPERATION" switch to the "DUAL MONO" position.
. strøken. Målt til 60W. Forsiktig brukt i rekkehus på Anthony Gallo høyttalere..
Mytek Broklyn Bridge.m/sbooster dac preamp kan kjøpes med for 19k. Nypris 33000,- Noe av det beste av lyd tilgjengelig for en fornuftig pris.
Se mine referanser.
Se mine referanser.
- Originalemballasje
- Nei
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
