Vurderer selge ett par Abrahamsen FS-401.
Lettdrevne høytalere med bra punch!
Som nye!
Nypris: 26,000
The FS401 uses 5 drive units from the highly respected manufacturer SEAS. The units are used in a 2½ way bass reflex design.
4 x Bass mid-range units 1 x Tweeter
Bass reflex design Listening area up to ±30°
Seas SpiderRing® technology Extruded aluminium profile
Direct Signal Connector (DSC) High gloss grand piano finish
Width(cm) 20.5 (24 w/base) Height(cm) 110
Depth(cm) 29 (35 w/base) Weight(kg) 25
In room frequency range: 35Hz – 35kHz
Impedance nominal: 6 ohm
Sensitivity: 92dB/W
Test fra AV Forum: http://avforum.no/forum/showthread.php/98638-Produkttest-Abrahamsen-anlegg
Som nye!
Nypris: 26,000
Sensitivity: 92dB/W
