4stk ubrukte presist mathchet THF 51S kjøpt fra Tomaki Watanabe med kvittering og måleskjema samt isolatorer selges.
Får ikke tid til dette prosjektet desverre. Nelson Pass har sagt han skal starte et prosjekt med disse som utgangspunkt på diyauido.
Matchet THF 51s koster 458usd pluss moms og shipping nå,. delges for 4000 for alt.
Følger også med 4stk custom Isolasjonspad / thermal pad produsert i Aluminium Oxide Al2O3 samt bushings, se bilder.
Material: Aluminum Oxide Ceramic(Al2O3)
Thermal Conductivity: 15~19 W/mK (compare with silicon pads' or rubber pads' datasheet...will see why prefer Al2O3 pads...AlN is much better, but the price is too high)
Dimensions: For Tokin V-Fet mentioned in caption, 1mm thick (can't be thinner, will be too fragile).
Digikey has some Aluminum Oxide Ceramic pads and can read datasheet there...
https://www.digikey.ca/en/products/...sDOBTANCAPZQDaIArAJwgC6AvvYQExkgAsYcADAOJ30gA
Application:
-Al2O3 pads, just like mica pads, need use thermal paste to fill the gap...non electronical conductive thermal paste;
-Al2O3 pads are ceramic, so a bit crispy...ensure the surface does not have sharp edge/bump, apply thermal paste on both sides of the pad, and when tightening screws don't use too much strength...once encounter resistance, just do a little bit more tightening, and then fix the screws with some easy to remove paint/glue...
Matchet THF 51s koster 458usd pluss moms og shipping nå (mao over 6000kr),. selges for 4000 for alt.
Application:
- Originalemballasje
- Ja
- Forsendelse
- Kan sendes
