SoundSmith hos Norsk Audio Teknikk AS
  • Vi har nå begynt å forhandle SoundSmith Pickupper.
    Har stort sett Otello, Carmen og Boheme på lager. Leveringstid på andre SoundSmith produkter ca 2-3 dager.
    Ullevålsveien 13
    0165 Oslo.
    Tlf: 22200095
    mail: morten@norskaudioteknikk.no
    Link prisliste: http://norskaudioteknikk.no/Priser/soundsmith-priser.pdf
    Soundsmith
    High output pickupper
    Otello
    Stylus: Elliptical Titanium Bonded, 0.20mm Round
    Radius of curvature: 6 x 17 µm
    Cantilever: Aluminum Alloy
    Recommended Tracking Force: 1.2 gm (Max)
    Effective tip mass: 0.50 mg
    Compliance: 28 µm/mN (high)
    Frequency Response: 20-20,000 Hz (±2.5 dB)
    Channel Separation: 1000 Hz: >24 dB 50-15,000 >20 dB
    Channel Difference: <1.8 dB
    Output Voltage: 2.2 mV
    Weight: 6.8 Gms
    Impedance: >/= 47 kOhms
    Capacitance: 100-200pF
    Carmen
    Stylus: Nude Elliptical, 0.120mm SQ
    Recommended Tracking Force: 1.4 gm
    Effective tip mass: 0.35 mg
    Compliance: 22 µm/mN
    Channel Separation:
    1000 Hz: >26 dB
    50-15,000 >20 dB
    Channel Difference: <1.6 dB
    Weight: 6.8 Gms
    Load:
    Resistance: >/= 47 kohms
    Boheme
    Stylus: Contact Line Nude, 0.120mm SQ
    Radius of curvature: Contact Line
    Cantilever: Ruby
    Recommended Tracking Force: 1.3 gm
    Effective tip mass: 0.32 mg
    Channel Separation:
    1000 Hz: >28 dB
    50-15,000 >20 dB
    Channel Difference: <1.4 dB
    Weight: 6.8 Gms
    Load:
    Zephyr
    Stylus: True Nude Elliptical, 0.120mm SQ
    Recommended Tracking Force: 1.8-2.2 gm
    Compliance: 10 µm/mN
    Body material: Corian and Brass
    Frequency Response: 15-45,000 Hz (±2.5 dB)
    Channel Separation:
    1000 Hz: >38 dB
    50-15,000 >25 dB
    Channel Difference: <0.5 dB
    Output Voltage: 2.4 mV
    Weight: 10.27 Gms
    Load:
    Aida
    Anmeldelse af Soundsmith Aida fra Audio Ideas her
    Stylus: Contact Line NUDE, 0.100mm SQ
    Radius of curvature: Optimized Contact Lin
    Cantilever: Ruby
    Recommended Tracking Force: 10mN / 1.0 gm
    Compliance: 22 m/mN
    Channel Separation:
    1000 Hz: >30 dB
    50-15,000 Hz: >20 dB
    Channel Difference: <1.0 dB
    Weight: 6.8 Gms
    Load:
    Capacitance: >/= 400 pF
    The Voice
    Stylus: Contact Line Nude, 0.100mm SQ
    Radius of curvature: Optimized Contour Contact Line
    Cantilever: Ruby
    Recommended Tracking Force: 1.3 Gm
    Effective tip mass: 0.30 mg
    Frequency Response: 20-20,000 Hz (±1.0 dB)
    Channel Separation:
    1000 Hz: >30 dB
    50-15,000 >22 dB
    Weight: 6.8 Gms
    Load:
    Resistance >/= 47 kohms
    Capacitance: 100 - 200 pF
    Low output pickupper
    Paua
    StylusContact Line Nude, 0.100mm SQ
    Radius of curvature Nude Contact Line SELECTED
    CantileverTelescoping Aluminum Alloy
    Recommended Tracking force:1.7 to 1.9 Grams
    Effective tip mass 0.30 mgCompliance10µm/mN (low compliance)
    Frequency response 20-20,000 Hz ± 1.0 dB
    Channel Separation (stereo only)
    1000 Hz >34 dB
    50-15,000 >25 dB
    Channel difference
    <0.5 dB (Stereo)
    <1.0 dB (Mono)
    Output @5 cm/sec0.3 mV
    Cartridge weight 10.25 Grams
    Loading:470 Ohm model Standard
    Loading range 300-800 Ohms recommended load
    Sussero
    Radius of curvature: Optimized Contour Contact Line SELECTED
    Cantilever: Ruby
    Channel Separation:
    1000 Hz: >34 dB
    50-15,000 >25 dB
    Output Voltage: >0.3 mV
    Weight: 8.79 Gms
    Load: >470 ohms, 1k-2kOhms recommended
    Hyperion
    Radius of curvature Selected Diamond shapes: CL or Optimized (OCL)
    CantileverHand formed/treated selected Cactus "Spine"
    Recommended Tracking force:1.8 to 2.2 Grams
    Compliance
    (LT) 12µm/mN vertical/7µm/mN horizontal
    1000 Hz >36 dB (LT: > 34dB)
    50-15,000 >25 dB
    Channel difference
    <0.5 dB (Stereo)
    <1.0 dB (Mono)
    Output voltage: 5 cm/sec. Lat. RMS0.3 mV
    Load:470 Ohm model now available
nat
nat sine annonser
En stor og tung nyhet ifra broderfolket!!!
  • 22
De første Bladelius Oden II er i ferd med å bli klare til levering. 85Kg med rå kraft og musikalitet. Norsk AudioTeknikk AS Sofiemyrveien 12. Inngang A1. 1412 Sofiemyr Tlf: 22200095 Mail...
Møt sommeren med godlyd på ørene!
  • 1
Vi har fått inn igjen den meget omtalte Cayin RU7 dongle DAC på lager. (Vi har også fått inn igjen Cayin CD-Mini MK-II. Kr 3.590.-) Prisen er Kr 3.590.- da medfølger USB-C kabel og overgang ifra...
Enda en glimrende test av Bladelius Ask integrert med DAC/Streamer. Nå i Norske Stereo+
  • 1
Etter en liten stund på markedet. Så har Bladelius Ask gjort seg sterkt bemerket hvor bra man kan få en alt-i-et forsteker med samme egenskapene som separate løsninger (bokser) Les hele testen på...
Lørdagen 6 april stenger vi kl 13.30 grunnet kundebesøk.
  • 8
Vi må dessverre stenge kl 13.30 i morgen grunnet kundebesøk. Skal kjøre halvveis opp til Trondheim og tilbake igjen i morgen. Er tilgjengelig på telefon. . Norsk AudioTeknikk AS Sofiemyrveien...
Da var det siste farvel til Ullevålsveien i dag.
  • 30
Sofaen er på plass i demorom Nr.1. Fortsatt mye jobb som gjenstår. Men dette blir bra🍾
Norsk Audio Teknikk flytter!
  • 117
Sofiemyr blir Mekka for troende audiofile:cool: Trommevirvel! Etter nesten tre tiår med å utvikle en mild avhengighet til bylufta i Oslo, har vi bestemt oss for å pakke sammen sirkuset og...
