Side 3 av 53 FørsteFørste 1234513 ... SisteSiste
Resultater 41 til 60 av 1046
Abonnér på denne tråden
  1. #41
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    hva ble dagens vintage kjøp??
    Navn:      ar-9(1).jpg
Visninger: 1275
Størrelse: 7.3 Kb
  2. #42
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    AR(Acoustic Research) AR-9
    278,000 yen(around the one-set and 1980 time)
    Description
    The large-sized Tallboy speaker system of the vartical series which also fully consider up the correspondence to high-output power amplifier, and was designed.
    Two 30cm corn type Woofers are adopted as low-pass, and it has composition arranged on both the sides of the enclosure. Furthermore, the wall dip phenomenon generated between a speaker and a back wall is canceled because crossover frequency shall be 200Hz.
    inside low-pass -- a 20cm corn type and a crown -- the unit of a 1.9cm dome shape is carried in the 3.8cm dome shape and the high region in the region.
    The inside low-pass unit is carried in the subenclosure, and has prevented the mutual intervention in a core.
    moreover, a crown -- the "magnetic fruid" of the shape of colloid which is tinged with the magnetism which NASA developed is put in between the voice coil of a region / high region unit, and the yoke. And distorted reduction was aimed at from the central axis as a structure as for which Bure is not, and the input-proof is improved.
    The electronic automatic transmission developed uniquely is adopted as the network part as an object for low-pass.
    This controls the low-pass characteristic automatically electrically like the missions of an automatic car,Without reducing a low-pass output, it operates so that dumping may become the maximum with resonance frequency, and even if it exceeds a bus spectrum about the part beyond resonance frequency, it switches electrically so that the flat characteristic may be secured.
    Moreover, a 17AWG sky core coil, a computer class electrolytic condenser, input-proof [ high ] ceramic resistance, etc. are adopted as the use element.
    The acoustic suspension system of AR tradition is adopted as the enclosure.
    By this system, air can achieve the duty of a spring by carrying out full sealing of the core, compliance can be enlarged, and it is possible to make low-pass resonance frequency lower.
    Moreover, the acoustic blanket which is a special sound-absorbing material was attached to the surroundings of a driver unit, and sound quality degradation by reflective sound is prevented.
    Finishing is walnut oil finishing.
    Rating of a mode
    System 4 ways, 5 speaker acoustic suspension system, and a Tallboy type
    Use unit For low-pass: 30cm corn type x2
    For inside low-pass: 20cm corn type
    a crown -- : for regions -- a 3.8cm dome shape
    For high regions: 1.9cm dome shape
    Frequency response 18Hz - 30kHz
    Low-pass play frequency 28Hz -3dB
    System Q 0.5
    Output sound pressure level 87dB/W/m
    Impedance 4ohms (a minimum of 3.2ohms)
    The continuation maximum input 175W
    The maximum input 400W
    Crossover frequency 200Hz, 1.2kHz, 7kHz
    Level control Low-pass: Automatic
    Inside low-pass: Three-step switching
    a crown -- region: -- three-step switching
    High region: Three-step switching
    Content volume 120L
    Dimensions Width 381x height 1340x depth of 402mm
    Weight 59kg
  3. #43
    Hifi Freak pekaill's Avatar
    Oct 2011
    Averøy
    Tagget i
    1 Innlegg
    Det var litt av noen høyttalere! Skriv gjerne noen ord om de
  4. #44
    Hifi-interessert Johan59's Avatar
    Nov 2015
    Tagget i
    0 Innlegg
    Sitat Sitat fra Kjell_Kranzberg Se Innlegg
    Dagens köp, Sony STR 3800L.
    Smutsig, men spelar.
    Jeg husker ikke denne som så veldig god lydmessig, men det er lenge siden jeg hørte den (1977 eller noe sånt. Du må gjerne korrigere meg når det gjelder lydkvaliteten. Men de har vist seg som svært solide og godt bygget ila. årene som har gått.
  5. #45
    Hifi-entusiast
    Jan 2011
    Tagget i
    1 Innlegg
    Hei !
    Har "kommet over" 2 gamle rør monotrinn fra Cary Audio som er merket CAD-80M og Signature Edition.
    Ser at Cary Audio fortsatt eksisterer og modellen CAD-805AE ser ut til å være en moderne variant av de jeg har.
    Noen som kjenner til disse gamle forsterkerne: All informasjon kan være av interesse.
    Melodiøs jazz og blues via
    1) Rega RP10 m Hana ML, ASR Mini Basis MKIV RIAA, Theta Pearl CD transport, Hegel HD20,
    Line Magnetic 518IA , Sonus Faber Amati Homage
    2) Sqb.Touch, Abrahamsen dac 6.0, Nobsound single-ended Class-A headamp, Denon AH-D5000 og AKG K240
  6. #46
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    det er vist ar 90 jeg har. men de er nesten like bort sett fra at de har 10 woofere i bunn i stedet for 12 og noe mindre kasse volum.
    de er vist et eiers par fra en pilot på Holmenkollen som hadde bytta de inn hos hifihuset på Nesbru.
    så på de når jeg kjøpte mine sony ss-2070 der og fikk de ikke ut av hodet.
    wooferne i bunn trenger ny skum ring men ellers er de hele og pene.
    men jeg lurer på om jeg skal bytte ut de i bunn med noe annet. må skaffe no verktøy til testing først. har noen 10 tommere liggende som jeg tror gjør susen
    noen som har hvert borti dayton audio wt3 woofer tester?
  7. #47
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    Navn:      DSC_0271.jpg
Visninger: 1190
Størrelse: 54.4 Kb
  8. #48
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    jeg lurer på og putte in disse
    Navn:      DSC_0278.jpg
Visninger: 1168
Størrelse: 52.8 Kb
    Navn:      DSC_0276.jpg
Visninger: 1135
Størrelse: 52.5 Kb
  9. #49
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    jeg tror det er bose drivere i som har blitt brukt i ar 9
    etter det jeg har funnet ut
  10. #50
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    eller skal jeg sette inn seas h336?
  11. #51
    Overivrig entusiast oen's Avatar
    Mar 2010
    Tagget i
    0 Innlegg
    Sitat Sitat fra vega jon Se Innlegg
    Reparer de som sitter der. Det er enkelt og bytte skumkanter.
    Hvis du setter inn andre må delefilteret endres.
    Verdien forringes.
    Kontakt Rick Cobb mulig han har nye kanter.
  12. #52
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    jo det er lett og få tak i rep sett men jeg tenkter på kvaliteten på driverne.her er et par bilder av filterne
    Navn:      DSC_0291.jpg
Visninger: 1115
Størrelse: 73.7 KbNavn:      DSC_0294.jpg
Visninger: 1147
Størrelse: 65.7 Kb
  13. #53
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    rep kit er greit og få tak i heldigvis
  14. #54
    Hifi Freak el_mariachi's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    dagens kjøp Vedlegg 359637
    Hvordan var disse lydmessig sett? Ble litt nysjerrig for bestykkningen ligner en del på KIT-303.
  15. #55
    Hifi Freak Kabeldragern's Avatar
    Jan 2003
    Kristiansund
    Tagget i
    0 Innlegg
    Kom over dette for noen uker siden. Yamaha M-45/C-45. Justerte bias og sjekket litt på effektforsterkeren. Den er ok. Preampen har "uttørkede kondiser-syndrom" og det knepper når tonekontroller av/på trykkes inn. Grei lyd på hytta! Bildet lånt fra nettet.
    Navn:      yamaha.jpg
Visninger: 1033
Størrelse: 56.2 Kb
    Information is not knowledge - Knowledge is not wisdom - Wisdom is not truth - Truth is not beauty - Beauty is not love - Love is not music - Music is THE BEST... - FZ
  16. #56
    Oct 2011
    Averøy
    Tagget i
    1 Innlegg
    Sansui AU-719 er på vei i posten.
    Bilde fra nettet. Den skal muligens erstatte en Marantz 2270 når FM blir stille.
  17. #57
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    har ikke fått spilt noe særlig på de enda da det datt in noen ar90 som har blitt stående og disse spiller bra! sannsynligvis den beste vintage høyttaler jeg har hatt.
    måtte sette ss2070 inn på kottet og legge de ut for salg:\ har for mye dill dall som tar plass
    av vintage har jeg hatt\har b&w dm6,b&w dm14,b&w dm 220,the advent 3,rogers ls3\5a,castle durham,t+a tmr70,jvc.sk44
    + sikkert noe jeg har glemt
  18. #58
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    som dac har jeg brukt en sony mds 920qs da jeg synes den låter bra.
    prøver og holde meg til en god digital kilde hvertfall men kjøpte meg en teac d-t1 i dag som jeg venter på da jeg savner
    en d500 jeg hadde. jeg spiller mest av fra pc btw. optisk fra pc til dac
  19. #59
    Hifi-entusiast
    Jan 2011
    Tagget i
    1 Innlegg
    Er dette helt ukjente greier ?
    Sitat Sitat fra Bidevind Se Innlegg
    Hei !
  20. #60
    Mar 2011
    bærum
    Tagget i
    1 Innlegg
    tydeligvis ingen her som har hvert borti cary.
    hvordan spiller de?
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
