- Ble medlem
- 02.05.2007
- Innlegg
- 293
- Antall liker
- 59
VTL TL 5.5 Signature Series 2 er en helt ny rørforforsterker.
VTL TL 5.5 Signature Series 2 er fullbalansert med balanserte innganger og utgang samt RCA innganger og utganger.
Finish muligheter er sort, sølv samt dual color : sølv + sort.
VTL TL 5.5 Signature Series 2 er en ekstremt god forforsterker som samtidig er i en rimelig prisklasse.
VTL TL 5.5 Signature Series 2 har mulighet for innebygd riaa trinn, og dette riaa trinn er bygget på toppmodellen VTL TP 6.5 Signature Phonostage.
VTL TL 5.5 Signature Series 2 forforsterker spesifikasjoner :
Main Features:
Almost half the price of the TL-6.5 Signature Preamplifier
Renewed cosmetics to match with Reference and Signature models
Fully balanced differential linestage with increased functionality
Optional internally retrofittable phono stage, with user adjustable cartridge loading and gain options
Engineering from TL/TP-6.5 applied to power supply and circuitry: Precision-regulated B+ and B- supplies
Tube life extender circuit with B+ delay and soft filament ramp on power on
Balanced design, low-radiation power transformer
Quiet logic: Microprocessor sleep mode, quiet non-matrixing LED display with latching shift registers
Line Stage: All-tube, with lower gain hi current 12AU7 circuit and 12AT7 buffer, minimal negative feedback
2 balanced /single-ended inputs, 5 single-ended inputs, 1 tape in, 1 bal / Single-ended out, 1 buffered record out
Soft-touch relay input select
128-step chip-based differential volume control, with 3-digit display
Higher resolution via single higher-resolution attenuator, and software control for balance and offset
Switchable gain between normal and low gain
Mono control on front panel
All TL-6.5 functionality, with fully bi-directional RS-232 control: First two inputs balanced or single ended, programmable input offset, any input programmable as pass-through, and input disable, tape monitor and Mono control on front panel
2 programmable trigger outputs
Metal remote
TP-6.5 chassis size with all precision machined aluminum cosmetic
Phono
VTL TL 5.5 Signature riaa/phono del spesifikasjoner :
Phono stage: JFET/parallel 12AU7 design from TP-6.5: 68dB gain balanced (23dB MC, 45dB MM)
Split-pole Passive RIAA with paralleled 12AX7 and 12AT7 gain stage
MM / MC select via jumper
MC Gain settings via jumper: 3 steps of 6dB: 68dB, 62dB, 56dB.
Loading: MM 47k, MC: 100 ohms, 500 ohms, 1k, 4.7k, UDF, 47k (parallel for more values) via jumpers
Enhanced RIAA (selectable via jumper)
Rumble filter setting via front panel
Selectable bal/ S/E output via jumper
Dual-use buttons on front panel for phono-only functions
MC and MM gain trims
Transformer option for MC stepup
Kontakt oss for mer info :
Hifi Stasjonen
WEB: www.hifistasjonen.no
Tlf mobil : 0047 40850814
Tlf butikk : 0047 62416121
Email : mail@hifistasjonen.no
Main Features:
Metal remote
Phono
Hifi Stasjonen
