U2 mini er klar.
Endelig er U2 mini klar, dette er en spiller mange har ventet på etter at U1 mini gikk ut av produksjon før jul i fjor.
Pris 26990,-
WHY LUMIN U2 MINI
Following in the footsteps of one of our most popular models, LUMIN U2 Mini introduces our all-new processing system, delivering greater flexibility and future-proofing.
Capable of upsampling and downsampling all the way from 44.1kHz to 384kHz/DSD256 and supporting playback of DSD512, LUMIN U2 MINI is the perfect streaming partner for your DAC.
Main features
  • Transport-only LUMIN for combination with an external DAC
  • The first LUMIN to feature our all-new processing system
  • Faster processor provides greater resampling flexibility - upsampling and downsampling to every supported format up to DSD256/PCM348 to hit your DAC's sweetspot
  • Increased capacity for future updates
  • New surface finish taken from the high-end P1
  • Quad native clock system for precision timing
  • 5 types of digital audio output including USB
  • MQA Decoding
  • Roon Ready
  • Leedh Processing volume control
Builds on the massive success of U1 Mini
Completely new processing hardware and software deliver improved features and increased resampling flexibility while retaining all the musicality that was noted in so many outstanding U1 Mini reviews.
Key hardware features carried over from U1 Mini include the quad clocking system and 5 different digital outputs with USB now capable of up to DSD512!
The new model is also finished in a new silky surfacing process taken from our high-end P1 that is less susceptible to finger marks and easier to clean.
All the usual LUMIN refinements
  • From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
  • Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
  • The unique and intuitive LUMIN App described as "fantastically intuitive and easy to use" by What Hi-Fi
  • LUMIN programme of continuous development that has seen Apple Silicon Mac support, TIDAL Connect, FLAC Lossless Radio and TIDAL Suggested/Related tracks added in 2021 alone.
READ MORE
Endpoint Audio
Endpoint Audio sine annonser
Acoustical Systems - Endpoint Audio
  • 3
Endpoint Audio gjenopptar agenturet for Acoustical Systems i Norge Jeg er stolt over å kunngjøre at Endpoint igjen er den offisielle distributøren av Acoustical Systems’ høykvalitetsprodukter i...
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
