Tull og tøys tråden, Vol II
Ivar_Loekken
Politikk gjort enkelt med kuer:
SOCIALISM:
You have two cows and you give one to your neighbour.
COMMUNISM:
You have two cows; the government takes both and gives you some milk.
FASCISM:
You have two cows; the government takes both and sells you some milk.
NAZISM:
You have two cows. The government takes both and shoots you.
BUREAUCRATISM:
You have two cows; the government takes both, shoots one, milks the other and throws the milk away.
TRADITIONAL CAPITALISM:
You have two cows. You sell one and buy a bull. Your herd multiplies and the economy grows. You sell them and retire on the income.
AN AMERICAN CORPORATION:
You have two cows. You sell one, and force the other to produce the milk of four cows. Later, you hire a consultant to analyze why the cow dropped dead.
A FRENCH CORPORATION:
You have two cows. You go on strike because you want three cows.
A JAPANESE CORPORATION:
You have two cows. You redesign them so they are one-tenth the size of an ordinary cow and produce twenty times the milk. You then create a clever cow cartoon image called Cowkimon and market them worldwide.
A GERMAN CORPORATION:
You have two cows. You re-engineer them so they live for 100 years, eat once a month, and milk themselves.
AN ITALIAN CORPORATION:
You have two cows, but you don't know where they are. You break for lunch.
A RUSSIAN CORPORATION:
You have two cows. You count them and learn you have five cows. You count them again and learn you have 42 cows. You count them again and learn you have 12 cows. You stop counting cows and open another bottle of vodka.
A SWISS CORPORATION:
You have 5,000 cows, none of which belong to you. You charge others for storing them.
A CHINESE CORPORATION:
You have two cows. You have 300 people milking them. You claim full employment, high bovine productivity, and arrest the newsman who reported the numbers.
AN INDIAN CORPORATION:
You have two cows. You worship them.
A BRITISH CORPORATION:
You have two cows. Both are mad.
A WELSH CORPORATION:
You have two cows. That one on the left is kinda cute.
lomt
To kuer stod på en eng.
Så plutselig sa den ene:
Møøøh
Da svarte den andre:
Faen, det var akkurat det jeg skulle til å si
Jan_I
Denne overskriften sto i en anonse Finnmark dagblad
og må vel være en stor selvmotsigelse:
" FERSK LUTEFISK "
Lurer på hvor de fisker dette siden den er fersk ::)
Mvh Jan I
Ivar_Loekken
Henvendelse til Teknisk Support:
I år oppgraderte jeg fra Kjæreste 7.0 til Kone 1.0. Jeg merket at
det nye programmet straks begynte å starte opp barneprosesser, og
det tok en masse tid og brukte en masse ressurser. Dette stod det
ikke noe om i produktspesifikasjonen for programmet.
Etter kjøpet installerte Kone 1.0 seg selv i alle andre programmer
og dukker opp så snart jeg starter PC'en, og det overvåker alle
mine aktiviteter. Gamle programmer som Pokeraften 10.3, Fyllefest
2.5 og Søndagsfotball 5.0 virker ikke mer, men får tvert imot
systemet til å gå ned, når jeg åpner dem.
Det er umulig å holde Kone 1.0 i bakgrunnen mens jeg prøver å bruke
noen av mine yndlingsprogrammer. Jeg overveier å gå tilbake til
Kjæreste 7.0, men jeg klarer ikke engang å avinstallere Kone 1.0.
Kan dere hjelpe meg?
På forhånd takk
Forvirret og Frustrert bruker.
Svar fra IT support:
Kjære FFB
Problemet ditt er veldig vanlig og mange klager over det samme, men
det skyldes hovedsakelig en misforståelse. Det er mange menn som
oppgraderer fra Kjæreste 7.0 til Kone 1.0 fordi de tror at Kone 1.0
hovedsakelig er et nytte- og underholdningsprogram. Der tar de
fleste feil.!!!
Kone 1.0 er et styresystem som er designet for å styre alt. Det er
umulig å fjerne Kone 1.0 for å gå tilbake til Kjæreste 7.0 når det
først er installert.
Noen har prøvd å installere Kjæreste 8.0 eller Kone 2.0, men de
endte med å få flere problemer enn de hadde med Kone 1.0. Vi
anbefaler at du beholder Kone 1.0, og gjør det beste ut av
situasjonen.
Du kan eventuelt lese hele kapittel 6 i manualen "Alminnelige
programfeil". Systemet vil kjøre perfekt så lenge du tar hele
ansvaret for alle "Alminnelige programfeil", uansett hva de
skyldes. Det beste du kan gjøre er straks å skrive: \UNNSKYLD før
problemløsning. I alle tilfeller må du unngå å bruke Escape-tasten,
for du vil allikevel være nødt til å bruke kommandoen: \UNNSKYLD,
for at styresystemet skal gå tilbake til normal.
Kone 1.0 er et flott program som vil gi deg livsglede og
interessante stunder, men det krever en høy grad av vedlikehold. Du
kan overveie å kjøpe mer software for å forbedre yteevnen. Vi
anbefaler Blomster 2.1, Sjokolade 5.0 eller i ekstreme tilfeller
softwarepakken Pels 2004. Men du må under ingen omstendigheter
installere Venninne-i-Miniskjørt 3.3. Dette Programmet støttes ikke
av Kone 1.0 og vil sannsynligvis få PC'en din til å bli helt død.
Alas
Vet ikke om denne er nevnt i enten tull og tøys vol1, eller på musikk-delen, but here goes nothing.
Sjekk det ut
Det er verdt det!!
jowil
Ser en helt klar sammenheng med Boffens siste innlegg.
Snickers-is
George Bush tok en joggetur utenfor det hvite hus og støtte på en liten gutt som satt med en pappeske med nyfødte hundevalper.
-Så søte! Sa Bush. -Hva slags hvalper er det?
-Republikanere svarte gutten.
Bush lyste opp og klappet gutten på hodet. -Det er gutten sin det!
Noen dager senere jogger Bush sammen med Dick Cheney forbi den samme gutten, som satt der med den samme esken og de samme hvalpene. Bush blunket til Cheney og sa til gutten:
-Hei gutten min, fortell Dick hva slags hvalper du har.
-Det er demokrater, svarte gutten.
-Demokrater? Her for litt siden sa du at de var republikanere!
-Jo da, men nå har de åpnet øynene sine.
Snickers-is
Nå føler jeg du er på flisespikkernivå her. Selv en liten dam må beskyttes.
lomt
Får håpe det var noen skikkelig gode høyttalere da
Gammel vits?:
-De nye naboene må være svært fattige.
- Å, hvordan det?
-Jo, du skulle hørt det spetakkelet det ble da den yngste sønnen deres svelget et kronestykke...
