Trenger hjelp til videoredigering
Bx
Vi har en festtale på film som vi ønsker å legge over på DVD. 17 minutter AVI format og mer enn det en DVD-rom har plass til. Jeg regner med at det finnes en eller annen konverteringsløsning her som gjør det mulig å få 17 minutter ned på en håndterlig størrelse og slik at det kan spilles greit av på en PC og/eller dvd-spiller.
Noen som har noen tips?
G
Gjestemedlem
http://www.cocoonsoftware.com/
Quick Media Converter is free software that can be used to convert video formats easily. It comes with an easy and expert mode to suite experienced and inexperienced users. The easy mode is basically a one-screen media converter. Users begin by picking the desired output format from a list of available ones.
Options range from high quality H264, NTSC or PAL DVD format over XVID, PS3, Xbox 360 to mobile phone formats. Videos can be dragged and dropped into the application. The user picks the output directory and clicks on the Start Conversion button in the last two steps. This is an effective method of converting media files on the computer system.
The expert mode provides access to additional features and settings which make it possible to optimize the output further. The video format, codec, aspect ration, bitrate and dozens of additional parameters have to be set by the user manually before the conversion can be started.
One of the main advantages of Quick Media Converter is the support of many different video formats without the need to install additional codecs to the computer system. The software program is very responsive and provides the right interface for both beginners and experienced users.
frans
17 minutter lang festale! Velkommen i klubben for lange festtaler ;D
På nettet skal det finne en rekke konverteringsprogrammer til DivX/MPEG4 dersom du virkelig ikke vil klippe litt i talen ;)
Kanskje denne siden kan være til hjelp.
Bx
Mange takk for tipsene.
