Testene av nye Lumin U2 mini begynner å komme, og som alltid er det gode omtaler.
LUMIN U2 Mini Review
Soundrebels have published not one, but two fantastic LUMIN U2 Mini reviews!
Marcin Olszewski and Jacek Pazio have both written about their enlightening time with our latest Streaming Transport.
"To put it bluntly, this is not in line with the price level and a similar impression could be expected from [products] at least twice as expensive." Marcin
"what reaches our ears is fully consistent with the pattern known from the real world." Marcin
"since you can have a higher-class source for practically the same amount as the older model generation, it is hard not to take advantage of this opportunity." Marcin
"The gentlemen from Lumin, in a manner known only to themselves, have so skilfully turned up the phenomenal presentation..." Jacek
"the general vitality and timing package perfectly helped to capture the virtual stadium stage" Jacek
"Lumin U2 Mini has a great chance to capture the hearts of the vast majority of the population" Jacek
"...we are dealing with a device worth, even if not buying blind, at least getting to know personally. Really worth it." Jacek
The full Polish review can be read here:
www.soundrebels.com/lumin-u2-mini-2
LUMIN U2 Mini Review.
Michael Lavorgna has published his very favourable review of LUMIN U2, describing it as "damn near transparent".
Writing for his own website Twittering Machines, Michael goes on to say...
"Regardless of the system it sat in, the Lumin U2 Mini offered a super clear view of the music in play."
"I have one very long Plus column and no Cons worth a mention"
"If you’re in search of a full featured streamer that does music proud by getting out of the way, this Lumin is one for the short list."
The full review can be read here:
www.twitteringmachines.com/review-lumin-u2-mini-digital-transport-streamer
Endpoint Audio
Endpoint Audio sine annonser
Canor Virtus A3
Canor Virtus A3
  • 1
Canors nye kreasjon Virtus A3 begynner å få flotte tester i hifi verdenen. LP International har tatt A3 under lupen og sett på hva som befinner seg under lokket. Dette er en alt i ett forsterker...
Flott test av den nye Canor A3 i Hifi Pig!
  • 2
Canor, en slovakisk produsent med 30 års erfaring i å lage høykvalitets HiFi-komponenter, har markert seg som en aktør å regne med i lydverdenen. Deres nyeste kreasjon, Canor Virtus A3, er en...
Acoustical Systems - Endpoint Audio
  • 3
Endpoint Audio gjenopptar agenturet for Acoustical Systems i Norge Jeg er stolt over å kunngjøre at Endpoint igjen er den offisielle distributøren av Acoustical Systems’ høykvalitetsprodukter i...
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
