Sutherland RIAA - DUO - testet i Stereophile
En av våre beste RIAAer - Sutherland: DUO er testet i Stereophile nå
Vi søker forhandlere i hele Skandinavia!!
https://www.stereophile.com/content/sutherland-engineering-duo-phono-preamplifier
Ren mono konstruksjon - 2 kabinetter og hver sin strømforsyning
Sutherland har de mest gjennomtenkte tekniske løsninger VI har sett
Ingen paralelle pasasjer mellom audio og AC
Ingen billige brytere / dip switch for endring av gain og impedance
Stereophile plasserer egentlig DUO i klasse med PhonoBlock - den tidligere toppmodellen - til langt høyere pris - og det er ganske ekstremt - for PhonoBlock er en ekstrem RIAA.
Så må det sies at i sommer ble PhonoBlock oppgradert - til et nytt nivå!!
Kommer egen info om dette asap
Pris på DUO: kr 52900,00
Ta kontakt for mer info om Sutherland - og for bestilling:
e-post: pmaudio@online.no
Tlf.: 0047-38 18 31 15
Til hjemmesiden:: PM Audio
Those images sounded three-dimensional, solid, tangible—I had the strong feeling that I could walk between, around, and behind the musicians. Compared to most other preamps I've heard, it was the Duos' coherence that was most striking.
Next up was the Duo's overall tonal balance, which I think of as the combination of frequency response, the timbres of instruments and voices, and how their transient characteristics vary with frequency. The first of these was easy: I heard nothing that suggested that the Duo's frequency response was anything other than flat. But it's the other two criteria that determine a component's overall tonal balance. Sutherland preamps have occasionally been described as having a rolled-off high end, or as lacking power on the bottom, criticisms I've understood but haven't shared. In the case of the Duo, debates about either are moot.
I've never heard any criticism of a Sutherland phono stage's midrange and I have none to offer here. Each instrument and voice had exactly the right balance of fundamental and harmonics, and the harmonic structures were complex and rich. One example of its superb sound in this regard was its reproduction of Suzanne Vega's voice in "Tom's Diner," an cappella recording from her Solitude Standing (LP, A&M SP 5136). Through the Duos, the combination of her odd rhythms and widely varying pitches and dynamic transients had me, hook, line, and sinker.
The word that appears over and over in the notes from my sessions with the Duos is articulate. The more I listened, the more I was convinced that that word nails it. Consider Al Di Meola, John McLaughlin, and Paco de Luc°a's Friday Night in San Francisco (Half-Speed Mastered LP, Columbia HC 47152): The first cut in particular, "Mediterranean Sundance/Rio Ancho," was a killer example of how cleanly and precisely the Duos could portray dynamic transients. With lesser preamps, the notes played by Di Meola and/or de Luc°a will be blurred across one or more narrow frequency ranges. With the Duos, each note in the blistering exchanges between the guitarists started and stopped sharply, regardless of the pitch, volume, or complexity of the transient itself.
pmaudio
pmaudio sine annonser
Nyhet fra Metronome - DSAS - Server / Nettverkspiller / Streamer m/Audirvana
Siste medlem i produktserien DIGITAL SHARING er på plass og på lager, DSAS, Metronome`s og vår første server for optimal presentasjon av digitalt lagret musikk. Inkludert 3 års avtale med...
Hifimessa Horten 20-21 September 2025
  • 4
I år kan vi av forskjellige årsaker dessverre ikke bygge opp den sedvanlige butikken vår på messa, som vi har gjort i alle år. Ingen plater, ingen Furutech produkter etc... Men det blir en liten...
Metronome: DST CD-transport / drivverk
Siste produkt i Digital Sharing serien, CD Transport Minimalistisk design Sammen med f.eks Metronome DSC MINI ( DA Converter ) i Digital Sharing serien får man plass til begge disse enhetene på èn...
Oslo HIFI Show 22-23. mars 2025
Så er det på tide å takke alle som var innom rommene våre på hifimessa sist helg, og TAKK til alle som ga oss supre tilbakemeldinger. Og meget hyggelig er det å treffe igjen sjeler vi er blitt...
Hifimessa i Horten 05 - 06 Oktober
  • 1
Takk for besøk på Løvøya ( demo ) og Grupperom 1 ( salg ) i helgen - og takk for alle godord på lyden vi fikk Etter et par stressende år privat greide vi endelig å gjennomføre en messehelg igjen...
Solid Tech - Balance mm...
Vi viser nå for første gang den nyeste serien til Solid Tech, BALANCE BALANCE - serien er bygget litt på samme lest som Radius-serien, med Monostand, 2 hyllers, 3, hyllers, 4 hyllers, 5 hyllers, 6...
