Still Harry after allt these years, Sheffield lab 1979 Vinyl
BangBang
Okka by
Sitter her og har et heftig hakeslepp....
På Hortenmessa plukket jeg med meg litt ymse med vinyl, og har hørt litt og litt.
I dag kom turen til plata "Still Harry after all these years" - Harry James and his big band.
Jeg er ikke akkurat på knærne etter Big band musikk, men denne plata tar kaka mtp. innspilling, og dynamikk :eek:
Dette er en Sheffield Lab "Direct to disc" plate.
http://www.allmusic.com/cg/amg.dll?p=amg&token=&sql=10:jvfwxq9gldhe
Litt morsomt når man finner den innspillingstekniske informasjonen sammen med platen.
Her står det bla.
"TECHNICAL INFORMATION
Recorded in Wylie Chapel March 26th trough March 30th. 1979. One stereo microphone utilizing Sheffiels Lab`s transformerless tube electronics was employed for overall coverage of the band. A touch-up microphone using Sheffiels Lab solid state slectronics was used on the piano, and a Telefunken 251 was utilized on the acoustic bass. All microphones featured captules manufactured by AKG. The signal was sent via cable 740 feet to The Mastering Lab and fed directly into tube cutting amplifiers. The lacquer masters where meticulously processed to metal by pur newly constructed matrix division. All stampers used for the pressing of this record are manufactured by Sheffield Lab. To best appreciate the wide dynamic range of this record, please turn your playback level up. Phonograph cartridges with excelent tracking ability should be used.
DOUG SAX"
;D
Absolutt en skive å anbefale, til og med for de som ikke faller innenfor målgruppen til "Big band" ;)
mteinum
Øya
Og følgende kan også anbefales på det varmeste:
Harry James & His Big Band [10057-2-G]
Dette er noe av den samme som den over, denne gang for CD. Dynamikk, trøkk, driv er ord som er beskrivende for denne.
10057-2 G THE BEST OF HARRY JAMES / Harry James and His Big Band. The best tunes recorded over a three year period. This compilation, taken from the three multi-award winning direct-to-disc recordings, is a comprehensive history of the Harry James Big Band and will make this Release the standard for Big Band Sound. Originally recorded direct-to-disc in the Wylie Chapel in Hollywood, this CD is re-mastered with Sheffield's 20+16 Ultra Matrix Processing from the original analog master tapes. Enjoy standards such as Count Basie's Corner Pocket, Caravan by Duke Ellington, and Benny Goodman's Don't Be That Way. Featuring Sheffield's HIGH DENSITY GOLD. A must for all your big band followers! "One of the best recordings I have ever heard!"-The Absolute Sound
http://dahlquistspeakers.com/Sheffield Recordings.htm
