Spotify Playback Output? (Kernel steaming og/eller WASAPI ???)
FAHLMAN
Er det noen workarounds eller plugins for Spotify som muligjør KERNEL STREAMING (KS) eller WASAPI for Playback Output?
Hvis jeg sjønner det riktig så er det kun DIRECT STREAMING (DS) som er muligt idag???
Bruker PC-HIFACE-DAC i mitt opsett. (fungerer glimrende med KS ved bruk av Foobar)
A PC with Windows Vista or Windows 7 can use hiFace in three different ways:
DirectSound (DS), Kernel Streaming (KS) and WASAPI. DS is suitable for players which can’t
operate in Kernel Streaming mode nor with WASAPI or for Internet streaming; KS can be
chosen (for better performance) with players which can operate in Kernel Streaming mode
(such as FooBar, Winamp, Monkey Media, JRiver). WASAPI (Windows Audio Standard
API) is a standard interface for audio players which allows to get the same performance of
KS with applications which can’t operate in KS mode, at the cost of higher CPU load.
Kernel Streaming or WASAPI has no standard setting in Windows 7.
KS or WASAPI must be selected in the specific player you choose to use.
For example, when using FooBar, with hiFace connected to the PC, go to the
File/Preferences/Playback /Output tab and select “KS: hiFace” as output device.
Other players will require different settings
Takk for svar / David
