Rogers export studio monitor
Bånnulka
Halden
Har et par slike som står her og spiller for tiden. Virker som en meget god høytaler,er egentlig overasket over at de er så gode alder tatt i betrakning. Bass er det i allefall nok av.:D Noen som kjenner til disse?
Mvh Roar
JanR
Mm, de jeg har funnet har også 4kant "blås" i front.
Tviler ikke på at S-500 spiller bra på de der. Prøvd 16ohm ?
Sitat:
The Export Monitors were a mod of the LS3/6 by Rogers on their own to make the speaker a better home product. This was especially to increase the power handling which was low on the LS3/6 partially due to a light voice coil structure with a paper former. I recall (over 25 years ago) that the LS3/6 had the most beautiful, slightly lush midrange of any speaker I had ever heard and I'm not sure if this still would not be true.
The BC1 was a pre-derivative of the LS3/6, but not a BBC model. Spencer Hughes had worked on the 3 way LS5/5. The BBC thought they could use the 8 inch mid of the LS5/5 to make a 2 way smaller monitor and they started to work on it. They stopped mid-stream and Spencer used the research to develop the BC1 on his own. It was originally a 2 way with just an HF1300. The STC super tweeter was added later. Meanwhile the BBC started the LS3/6 work again and finished it. Rogers took on the manufacture and they proposed adding the HF2000 super tweeter which the BBC approved.
Sitat slutt.
Du får knipse ett par bilder å legge ut. Uten frontstoff da selvsagt.
/jan
Bånnulka
Halden
Skal legge ut noen bilder etterhvert Jan. Får vel finnere disse,er ikke pene slik de ser ut nå. De er verdt og ta vare på. Lyden lever jeg med. Prøve Luxman forsterkeren på de etterhvert.
Mvh Roar
JanR
Mvh Roar
Fant du ut noe mere ang firkant "blås" kontra rundt ?
Alt jeg finner, så langt, er med firkant "blås"
Uansett, ser det det er flere bortover som liker de :)
/jan
Bånnulka
Halden
Mvh Roar
/jan
Lurer på om disse kom før disse med firkant blås. Spendor har noen som ligner med rund blås. Spendor bc1. Men den har blåsa rett under basselementet. De jeg har er på siden slik de som er avbildet. Spiller bra med god vintage bass og de passer meg perfekt. De fortjener og bli resturert og få et godt hjem.
Mvh Roar
