Sitter og kikker på Pure Vinyl for OS X. Med eksternt lydkort har eg mulighet til å køyre vinyl gjennom OS X og Core Audio.
"Used with a quality audio interface, Pure Vinyl is capable of providing stunningly dynamic, detailed music reproduction, faithfully preserving and conveying all of the music contained in the grooves of your vinyl records."
Her er det mulighet for å digitalisere, samt kjøre signalet rett igjennom.
Monitor the input audio for live vinyl playback: use Pure Vinyls extremely accurate, 64-
bit RIAA standard vinyl correction curve in conjunction with a straight wire preampli?er
setup to enjoy pristine, low distortion playback of your vinyl records.
Record input audio from a variety of sources at high resolution, up to 192 kHz / 24 bit, with
very high CPU ef?ciency.
Se meir på http://www.channld.com/pure-vinyl.html
