Paradox Audio nå med Interconnects
Paradoxaudio
Paradox Audio slipper endelig sine planlagte high end signalkabler. De kommer i både ubalansert RCA og balansert XLR variant med de originale navnene ”Unbalanced” for RCA og ”Balanced” for XLR versjonen. Begge har ledere av høykvalitets kobber, dobble lag skjerming og har veldig gode inductance/capacitance verdier. De blir levert i par med Rhodium platerte kobberplugger for både XLR og RCA versjonen.
Unbalanced RCA interconnect:
Unbalanced RCA interconnects with double shielding and incredibly low capacitance and inductance. Made with the purest of copper, silver and connectors of rhodium plated tellurium copper, it has the same conductivity to pure copper but with much higher hardness and shown oxidation resistance. Each connector is housed in a carbon cover and the cable is wrapped with exclusive braided sleeving making this interconnect truly worthy of the most expensive of high end setups
with extremely low distortion and signal loss enhancing crystal clear sound.
Conductors2x24 AWG (2x0,34mm) Extremely pure copper 99,99% with silver soldering
Connector Carbon housing with rhodium plated tellurium copper.
Tellurium copper: 99.5% copper, 0.5% Te and 0.008% phosphorus
InsulationLayers of PVC and PE. Double shielded with aluminum foil, copper mantel and bicoupled copperwires. All wrapped in high class braided sleeving
Measurements0,31 inches diameter (7,6mm diameter)
Resistance0,01614 Ohms per foot (0,02105 Ohms per M)
InductanceBelow 0,1 uH per M
Capacitance22,86 pF per foot (75 pF per M)
Balanced XLR interconnect:
Balanced XLR interconnects with double shielding and incredibly low capacitance and inductance. Made with the purest of copper, silver and connectors of rhodium plated tellurium copper, it has the same conductivity to pure copper but with much higher hardness and shown oxidation resistance. Each connector is housed in a carbon cover and the cable is wrapped with an exclusive braided sleeving making this interconnect truly worthy of the most expensive of high end setups with extremely low distortion and signal loss enhancing crystal clear sound.
Conductors4x26 AWG (4x0,22mm) Extremely pure copper 99,99% with silver soldering
InsulationLayers of PVC, PE and ultrathin SFRS covered with thread. Double shielded with aluminum foil, copper mantel and bicoupled copperwires. All
wrapped in an exclusive braided sleeving
Measurements0,4 inches diameter (9mm diameter)
Resistance0,02567 Ohms per foot (0,03349 Ohms per M)
Capacitance25,86 pF per foot (84 pF per M)
www.paradox-audio.com
Paradoxaudio
Priser starter fra 16990.- per par for RCA og 22990.- per par for XLR
Grace
Beklager,- men markedet er vel forlengst mettet hva angår kabler;- mitt råd:- velg kabler fra velkjente produsenter som over tid har etablert troverdighet.
Grace
mr.chill
Grace
Isåfall kan man bruke den logikken på høyttalere også, finns jo uttallige produsenter, er vel bare ta en tur på en messe for å trekke konklusjonen om at markedet er mettet på høyttalere også, skal man da bare holde seg til de som er velkjente?
Grace
Må gjerne anvende min logikk på hvilke produkter som helst;- imidlertid vil undertegnede være særlig aktsom i relasjon til kabler,- og anbefaler fortrinnsvis produsenter med kjent historie,- for å si det slik.
Grace
mr.chill
Grace
Det får være din sak. Jeg derimot velger kabler som faktisk har noe for seg med tanke på elektriske egenskaper og tverrsnitt, det at et kabelfirma har lang historie har lite å si når de har diktet opp en hel haug med teorier og fancy ord som liksom skal gjøre en kabel bedre. Ser ikke hvorfor Nordost feks skulle være en bedre kabelprodusent velge bare fordi de har lang historie når eventuelt spesifikasjonene skulle være dårligere.
Med tanke på kabler så stoler jeg heller på de som ikke dikter opp hokuspokus og kun holder seg konkret til fysikkens lover.
