Paradigm Persona-måned - Persona 9h
    I løpet av oktober vil vi presentere de ulike modellene i Paradigm sin Persona serie. Som mange har fått med seg er Paradigm Persona en av de mest roste høyttalerserier de siste årene i høyere prisklasse.
    Siden vi er litt sent ute, så kommer 9H i denne omgang, og 7F om kort tid.
    Persona 9H - En av de beste
    Persona 9H er i en rekke omtaler omtalt som en av markedets aller beste høyttalere uansett pris. Ofte blir 9H satt opp mot konkurrenter som koster opp mot 1mill. Ikke bare blir den anmeldt likeverdig, den blir også foretrukket. 9H er en rå høyttaler med oppløsning, fundament, autoritet og kontroll. De aktive bassene sørger for godt fraspark, og romkorreksjonen kan redusere problemer i bassområdet.
    Les hva pressen sier:
    "...the Paradigm Persona 9H is a superb speaker system for the money and also provides dedicated room-frequency compensation in a more purist form. Both products show that room compensation is now available in far better sounding forms, can deal effectively with room interactions and speaker locations, and significantly improve key aspects of the realism of the listening experience in any system. The promise of digital processing has been around for years. Legacy and Paradigm show that this promise is now really being kept."
    —Anthony Cordesman, The Absolute Sound
    "Good things do come in rela- tively small packages, although this is a nearly 300-pound speaker that is 51" high. It uses four new ultra-high ex- cursion woofers, two 700-watt amps, and ARC-2 digital room compensation to produce incredibly deep, accurate bass at to 19Hz and going as low as 15Hz. It also features an advanced beryllium tweeter and midrange driver, and provides equally outstanding midrange and treble perfor- mance in every aspect. Detail, dynamics, depth, and imaging are all excellent. Sensitivity is 96dB, allowing use with even low-power triodes and pro- viding an exceptional sense of life with more powerful amps."
    —The Absolute Sound
    "Paradigm has created one of the world’s finest loudspeakers the right way, by applying what they’ve learned from decades of research, design and manufacturing know how to produce a speaker with no compromises. There’s nothing they don’t do, nothing they won’t play and from what I can deduce, nothing they won’t partner with regarding electronics."
    —Jeff Dorgay, TONEAudio
    "Sometimes, music can feel like magic. Hearing a familiar song can send chills up your spine, change your entire mood, or even take you to the same place you first heard it. Of course, music is only as good as the tools used to play it. Enter the Paradigm Persona 9H. Acoustically, the Persona 9H can out-muscle heavyweights twice its price. The 1-inch tweeter, 7-inch mid/bass driver, and four 8.5-inch woofers are calibrated with Anthem Room Correction, powered by separate DSP-controlled 700W amps, and wrapped in a housing that oozes audiophile distinction."
    —Patrick McCarthy, Sr. Content Editor, Dealerscope
    "Paradigm Persona 9H Loudspeaker is a state of the art speaker designed by one of Canada's leading audio companies. It may be expensive but it's one of the best speaker systems in its class. It delivers superb upper-octave and midrange response, and it can deliver flat, detailed, and room-corrected bass that normally requires a massive separate subwoofer.".
    —David Richards, Smarthouse [Australia]
    Kampanje
    Vi kommer i løpet av oktober til å kjøre kampanje på hver modell vi presenterer. Kampanjen varer frem til neste modell presenteres.
    Kampanjen på Persona 9H varer frem til og med onsdag 31.10.18
    NB! 6 måneders prisgaranti. Vi garanterer at produktet vil ikke komme på kampanje til samme eller lavere pris innenfor en periode på minimum 6 mnd.
    Kampanjen vil også være tilgjengelig gjennom din foretrukne forhandler.
    Persona 9H Standard utførelse: 269.990,- (349.990,-)​
    Kontakt oss gjerne for mer info på salg@lydcompagniet.no eller tlf 40104600
    erk
    Tårnåsen
    Har et par 9H som drives av en ASR Emitter II Exclusive HV.
    Veldig fornøyd, spesielt mellomtonen er fantastisk og med en dynamikk og "tyngde" jeg aldri har hørt før.
    Og så er de veldig morsomme i bassen ;-)
    Topp sub-bass ytelse uten de vanlige utfordringene man nesten alltid har med å få det optimalt integrert med eksterne subber.
    Fortjener kraftige og ikke minst presise effektforsterkere selv om man skulle tro noe annet. Mine forrige EC monoblokker ble for vassent med 9H.
    Lurte først på om jeg skulle forsøke å matche med rør men er utrolig fornøyd med 9H+ASR komboen som skviser ut alt av detaljer som er i kildene og brer dette ut over et grandiost lerret.
    GSolie
    Eydehavn
    Så hyggelig at du er fornøyd med 9H. Det er en fantastisk høyttaler på mange måter. Når du får satt de opp skikkelig så biter de godt i fra seg.
    Det du nevner med problemer med å integrere eksterne subwoofere handler nok i de aller fleste tilfeller om at mange angriper dette på feil måte. Nå er jo heller ikke de aktive bassene i 9H subwoofere da de spiller langt opp i midbassen.
    Kos deg masse med dine 9H
    erk
    Tårnåsen
    Ja de må plasseres med omhu og jeg eksperimenterer fortsatt. Ift bass: Jeg uttrykte meg sikkert litt klønete men poenget mitt var mest at de spiller fra det dypeste du har behov for uten ekstra subber (måler pent ned til 15Hz hos meg og veldig sømløst i hele bassområdet), med mindre de skal inn i en ganske grov hjemmekino da ;-)
    Lockis
    Grattis erk, fantastiska högtalare
    Jag har själv köpt Persona 7F och är fantastiskt nöjd
    Har aldrig haft så bra ljud som nu hemma hos mig, provar lite olika slutsteg, har inte bestämt mig ang. Slutsteg ännu men 7F verka r inte vara svåra att driva
    Mvh Bengt
    GSolie
    Eydehavn
    Du var på ingen måte klønete i formuleringen, var vel heller at jeg følte behov for å konkretisere litt. Når det er sagt så er det svært mange subwoofere som ville slite med å gjøre det samme som de 4 bassene i 9H gjør, selv nedover i frekvens.
    GSolie
    Eydehavn
    Mvh Bengt
    Gratulerer med 7F Bengt. En veldig morsom høyttaler. Kos deg i forsterkerjakten!
    erk
    Tårnåsen
    Mvh Bengt
    De elementene i Persona er godsaker. En ting som jeg innser nå etter noen mnd er hvor bra det låter også når man spiller LAVT, og da fortsatt med så mye detaljer og dybde i lydbildet! Og akkurat det er kanskje ikke noe man sjekker ut på "demokveld", men som jeg setter mer og mer pris på... Men likevel, jeg endte som sagt opp med en ASR selv om 9H ikke trenger all den strømmen som den kan tilby og jeg stort sett spiller godt innenfor "klasse A" bias (20W på ASR). Noe du bør prøve? Jeg mener jo kanskje at alle burde prøve en ASR hvis det er innenfor budsjett (ligger en herlig brukt en ute på torget for 1/3 av nypris, og det må være et kupp). Jeg har i hvert fall aldri hørt maken... Lykke til :)
GSolie
GSolie sine annonser
AudioSolutions med ny høyttalerserie
Lydcompagniet AS presenterer AudioSolutions Virtuoso M AudioSolutions blir ofte omtalt som et av de mest spennende høyttalerprodusenten akkurat nå. Både Overture, Figaro og Vantage får...
Sommerkupp fra Lydcompagniet
Vi roer ned før sommeren med knallpriser på knallprodukter Av helsemessige årsaker har det skjedd store endringer hos Lydcompagniet de siste mnd. Av nevnte årsak måtte det gjøres nøye...
Nytt norsk høyttalermerke under etablering
  • 68
Lydcompagniet AS presenterer Det etableres i disse dager et nytt selskap som skal utvikle høyttalere og annet relatert til bransjen. Selskapets navn blir Norse Audio AS og merkevaren Norse...
Bli kjent med Cocktail Audio
Cocktail Audio Det prisgunstige High End alternativ Cocktail Audio er kanskje ikke det mest kjente merket blant streamere, men du må gjerne betale endel mer for de mer kjente merkene, skal du...
Kampanje på IsoAcoustics
  • 7
Vårkampanje på IsoAcoustics hos Lydcompagniet AS Det er ikke mye tilbehør som har fått så mye ros og utmerkelser som IsoAcoustics. Produktene er ikke bare populære i HiFi miljøet, men brukes...
Dutch & Dutch 8c Kampanje
Lydcompagniet presenterer D&D og Cocktail Audio Super-bundles Som flere kunder har fått oppleve i det siste, er det lang ventetid på Dutch & Dutch 8c. Etterspørselen er større enn...
