OSMC Vero V lanseres snart
TGB
Asker
CPU
  • AMLogic S905X4-OSMC
  • 4x ARM Cortex A55 @ 2GHZ
  • Built in RISC-V core for OSMC SecureOS Trusted Execution Environment
GPU
  • 2x ARM Mali G31 @ 850Mhz
  • OpenGL ES 3.2, Vulkan 1.1 and OpenCL 2.0 support
Memory
  • 4GB LPDDR4 RAM
  • 32GB eMMC connected via SDIO bus
Supported video playback formats:
  • AV1 MP-10@L5.1 up to 4Kx2K@60fps
  • VP9 Profile-2 up to 4Kx2K@60fps
  • H.265 HEVC MP-10@L5.1 up to 4Kx2K@60fps
  • AVS2-P2 Profile up to 4Kx2K@60fps
  • H.264 AVC HP@L5.1 up to 4Kx2K@30fps
  • MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
  • WMV/VC-1 SP/MP/AP up to 1080P@60fps
  • AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
  • MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
  • MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
Supported audio playback formats:
  • LPCM7.1 output up to 192Khz PCM
  • Bit-perfect passthrough of major audio formats including DTS-HD Master Audio, DTS: X, Dolby TrueHD and Dolby Atmos
Video Playback:
  • HDR10+, HDR10, HLG and Technicolor HDR processing
  • OSMC video enhancement running on dedicated RISC-V core
  • Frame Packed 3D, 3D Side by Side and and 3D TAB output
  • Motion compensated noise reduction and 3D digital noise reduction for random noise
  • Block noise, mosquito noise, spatial noise, contour noise reduction
  • Motion compensated and motion adaptive de-interlacer
  • Edge interpolation with low angle protection and processing
  • 3:2/2:2 pulldown and Video on Film (VOF) detection and processing
  • Smart sharpness with SuperScaler technology including de-contouring, de-ring, LTI, CTI, de-jaggy, peaking
  • Dynamic non-Linear contrast enhancement
  • All dimension multiple regions smart color management including blue/green extension, flesh-tone correction, wider gamut for video
  • 2 video planes and 3 graphics planes hardware composer
  • Independent HDR re-mapping of video and graphic layer
  • Trusted Video Pathway with Widevine L1 and HDCP2.2 attestation (for industrial customers)
Video Output:
  • Built-in HDMI 2.1 transmitter including both controller and PHY supporting eARC, CEC, Dynamic HDR and HDCP 2.2/2.3, 4Kx2K@60 max resolution output
  • CVBS 480i/576i standard definition output
Connectivity:
  • 2x USB 2.0 ports (1x USB 2.0 internal) with maximum 0.5A output
  • 1X USB 3.0 port with maximum 0.9A output
  • micro SD card and SDIO interface with 1-bit and 4-bit data bus width supporting spec version 2.x/3.x/4.x DS/HS modes up to UHS-I SDR104
  • 802.11ac/n/g/b WiFi
  • Gigabit Ethernet
  • Bluetooth 4.0
  • CVBS output
  • HDMI 2.1 output
  • Optical audio port
  • Built in IR receiver
  • Built in RF receiver (compatible with OSMC remote only)
Form factor: 11.5cm x 11.5cm x 2cm
Weight: 178 grams
Får tilsendt 2 av disse (får lov å teste dem før lansering, kunne fått dem for et par uker siden, men jeg klarte ikke svare på spørsmålet jeg fikk om jeg ville ha tilsendt før i går).
TGB
Asker
Har hatt dem kjørende i en god måned nå; alt fungerer som det skal og overføring av innstillinger fra Vero 4K+ gikk uten problem. Kjører en i stua og en på soverommet, med MariaDB database for kodi kjørende på Synology NAS (gjør at hva som er sett, favoritter osv er felles for dem begge - samt et par andre enheter som kjører kodi er også koblet opp). Forbedringer sammenlignet med forrige utgave, merkbart raskere respons på grenesnittet (selv med ekstreme mengder titler i systemet), og bildekvaliteten på video mener jeg er noe bedre uten at jeg har gjort noe ABX sammenligning.
Vero V er tilgjengelig for kjøp, men nettbutikken til OSMC er ikke helt on track ennå.
TGB
Asker
Dedikert Linux basert boks som kjører kodi, naturligvis kan man bruke addons for streamingtjenester - men hovedbruken er å spille av DVD, Blu-ray, UHD blu-ray ripper (med bilde og lyd som fra det originale optiske mediet). Jeg pusher alltid alle mine filmkjøp til NAS boks, så bruker jeg Vero V til å spille av (eget spesialdesignet menysystem, men jeg er så gammel og kjedelig at jeg bruker kodi slik som jeg mener kodi skal se ut - dvs som det leveres fra kodi).
Multikanal
Nordfjordeid
OK, takk for utfyllende svar. Ingenting for meg da som spiller Blu-ray, UHD blu-ray, SACD og DVD-A fra disc og streamer Atmos musikk fra Apple Music på ATV 4K. ;)
Reaksjoner: TGB
