Nyheter fra Bricasti
Bricasti har nå lansert et par nye modeller i sin serie.
Forforsterkeren M12 og stereotrinnet M15. Prisene vil ligge på hhv. 175.000,- og 195.000,-
[h=3]The Bricasti Design[/h] [h=1]Model 12 Dual Mono Source Controller[/h] The new M12 is a modern front end to any system. All digital inputs types are supported as well as balanced and unbalanced analog inputs, all with precise analog gain control, seamlessly integrated into one product, your source controller.
The M12 builds upon the proven design of the M1 SE D/A converter so your digital sources are handled and converted in the best way. To that we add to it a pure dual mono analog signal path with high resolution analog gain and level control, controlling the output stage of the D/A converter in the analog domain with no loss of resolution and pass thru analog inputs for your analog sources. Like the M1, the M12 is a dual mono design with 3 power supplies and separate left and right analog power supplies and digital and analog processing.
[h=1]Network Streaming[/h] A new feature for the M12 is a network interface and media renderer. This allows the M12 to be seen as a DNLA device on an audio network and server as an audio device to play or stream to through a wired connection on your network. Now you can run wired data longer distances without loss in quality so your network server can go anywhere you choose.
[h=1]DSD to new heights[/h] Analog gain control has allowed us to take DSD playback to the ultimate level. The M12 features a pure analog DSD converter; any filtering and level is accomplished in the analog domain. When processed this way, no digital signal processing is done. Typically in most DACs the DSD is converted to a multi-bit sigma delta or PCM signal for filter processing. With the M12 we offer a pure DSD path and all post processing for noise filtering and level control are accomplished purely in the analog domain.
[h=1]Analog level[/h] All analog, precise, silent control with 90db of control range in one db steps, all remote controlled and programmable. The M12 digital controlled fully balanced dual mono resistor ladder is as good as level can be, and inserted at the source, at the output of the DAC’s I-V stage. This approach provides some of the best digital playback possible and analog control from the M12 balanced or unbalanced inputs.
[h=3]The Bricasti Design[/h] [h=1]Model 15 Stereo Power Amplifier[/h] The Bricasti M15 stereo amplifier is the beating heart of any system and in particular, a Bricasti Design system. Like its bigger mono-block brother the M28, the M15 delivers heaps of power at critical stages, forging a sonic path of least resistance all the way from source to the speaker. This can be heard and felt and is in part thanks to its fully differential / balanced architecture.
[h=1]Precise control[/h] The power amplifier is a very critical part of the audio chain. It has to take the incoming signal and amplify it and most importantly, deal with the load of the loudspeaker and control its back EMF with precision. The sound of the M15 is intended to be transparent and revealing with low distortion, and fully dynamic with no sense of limits and compression in the reproduction, on any loudspeaker.
[h=1]Balanced power[/h] The M15 stereo power amplifier is a true reference design in analog power amplification, an uncompromising design offering extremely low distortion with moderate power and a unique truly balanced topology rarely seen in the industry. When combined with our M1 DAC or M12 Source Controller driving the M15 one can achieve a fully differential signal path, from the converter to the loudspeaker.
[h=1]Modern application[/h] The intention of the M15 is to integrate seamlessly into your existing system while allowing for a more compact form factor. A unique features like trim control lets you properly gain stage the M15, critical with todays digital sources driving the amplifier directly. You also enjoy the same sonic benefits of the M28 monoblock with the stillpoints isolation designed directly into the feet.
Tom Egil
tom@endpoint-audio.com
47832922
Endpoint Audio
Endpoint Audio sine annonser
Thales Elegance – Årets produkt i LP Magazine
  • 1
Thales Elegance – Årets produkt i LP Magazine. Micha Huber som eier HiFiction hvor man produserer Thales og EMT, er hele tiden fokusert på nyvinninger og hvordan man kan få max ut av analog...
Godt Nytt År!
Godt Nytt År!
2025 – Et fantastisk år for analog lyd hos Endpoint Audio 2025 ble et virkelig eksepsjonelt år for Endpoint Audio. Jeg opplevde et rekordår i salg av analogt utstyr – platespillere, pickuper...
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
Lockwood Loudspeakers - Endpoint Audio
  • 12
Endpoint Audio presenterer: Lockwood Loudspeakers – Et legendarisk britisk merke gjenfødt for ekte audiophile. For halvannet år siden – i mai 2024 – sto vi klare til å lansere Lockwood...
J.Sikora Aspire.
J.Sikora Aspire.
  • 2
Nyhet: J. Sikora Aspire – Den nye inngangsporten til high-end vinyllyd! Vi har spennende nyheter fra den polske high-end produsenten J. Sikora. Selskapet, grunnlagt av Janusz Sikora, har...
