Nyhet fra Ifi Audio!
Audio aktøren presenterer Ifi Audio ZEN One Signature! Kun kr 3995,- og er på lager!
Our ZEN One Signature takes the DAC stage from the ZEN DAC V2, adds S/PDIF inputs (optical and coaxial) alongside the USB port, stirs in Bluetooth technology from the ZEN Blue V2 and seasons the pot with Signature-grade circuit enhancements to create a delicious audio brew.
The result? The ZEN One Signature is a pure DAC (no built-in headphone amp and volume control) that serves as a home audio hub for all your digital devices, from smartphones and tablets to PCs and Macs, disc players and audio servers to TVs and games consoles.
Home Hub DAC
The ZEN One Signature is the first ZEN DAC to support all hi-res: DSD256, PCM384, MQA384kHz, Bluetooth 96KHz.
  • 96kHz Hi-Res Bluetooth: LDAC, HWA/LHDC, aptX Adaptive/HD/LL, AAC
  • USB audio using 16 Core 2000MIPS XMOS low latency microcontroller (MQA decoder)
  • Fully balanced 4.4mm output
Purity of design, no headphone amp, no volume control. The ultimate DAC for all your home audio sources.
Her er litt om hvordan verdenspressen føler produktet er:
"iFi's Zen One Signature combines the talents of five-star Zen DAC and Zen Blue
By Becky Scarrott published 18 days ago
iFi says: be at One with your sound
Award-winning audio specialist iFi has just expanded its Zen Signature range – which the firm describes as "enhanced, premium-grade devices based on the acclaimed entry-level Zen Series – with the Zen One Signature.
It is described as a ‘universal DAC’ owing to its all-encompassing input options and it takes the DAC stage from the What Hi-Fi? 2021 Award-winning Zen DAC V2, adds S/PDIF inputs (optical and coaxial) alongside the USB port, stirs in Bluetooth technology from the five-star Zen Blue V2 and finished with Signature-grade circuit enhancements. The result is a pure DAC (no built-in headphone amp or volume control) that serves as a home audio hub for all your digital devices, from smartphones and tablets to PCs and Macs, disc players and audio servers to TVs and games consoles.
The Zen One Signature’s singular purpose is to take the digital audio signal from any device, via cable or Bluetooth and convert it to analogue to feed an external amp and speakers (or headphones). Coupling high-quality internal components with iFi’s proprietary circuit design, it promises a brilliant boost to sound quality, however your devices connect to it.
How does the Zen One Signature differ from its ‘regular’ Zen device counterparts? Well, iFi's entry level Zen series introduced the benefits of balanced circuit design (lower noise, greater sonic purity) at affordable prices, but the Signature-level Zens, such as the Zen DAC Signature and Zen Can Signature, should further up the ante with their enhanced true-differential balanced topologies – and the Zen One Signature is no exception. From input to output, iFi assures us every element of its circuitry is designed for pure performance."
Vi har den som sagt på lager, og prisen er kun kr 3995,-
Vi kan kontaktes på tlf og mail: Jon 92063085 jon@audioakt.no og Terje 90762967 terje@audioakt.no
Ring, send mail, eller kom innom butikken. Ta gjerne en titt på vår webside også! Webshopen vår er oppe og går, og det blir lagt ut nye produkter kontinuerlig.
Gi oss gjerne en tilbakemelding! Om du ikke finner det du leter etter, eller du faktisk ikke vet helt hva du leter etter, så ta kontakt da vel! Vi hjelper deg med ditt HiFi-oppsett.
Roberth
Som eier av dac signature av dac signature og savner optisk, er det ekstremt ergelig å måtte betale høyere pris og ofre volumkontrollen for å få noe som burde vært essensielt på en hver dac.
Uansett en veldig god dac så totalt sett er jeg veldig fornøyd.
Audio Aktøren
Audio Aktøren sine annonser
Verdens premiere fra Qualio "Cube" Horten Messa 20 til 21 september
Consolidated Audio Berlin på Hortenmessa!
  • 1
Consolidated Audio Berlin på Hortenmessa! ALT du ville vite om Step Up Transformatorer, men aldri turte spørre. Ingen spørsmål for dumme - ingen for vanskelige! Har du allerede en Ortofon...
Først gang vist på Horten messa i Norge den 20-21 september
Først gang vist på Horten messa i Norge den 20-21 september Qln One V7
Skandinavisk premiere på Hi-Fi Messen i Horten Audio Analouge ABsolut Pre og power nesten 200Kg med forsterker
Skandinavist premiere på Hi-Fi Messen i Horten Audio Analouge ABsolut Pre og power nesten 200Kg med forsterker
For første gang skal Franco Serblin Accordo Essence vises frem på en Hi-Fi messe i Norge, og det skjer i Horten 20.-21. sept.
  • 4
For første gang skal Franco Serblin Accordo Essence vises frem på en Hi-Fi messe i Norge. Dette skjer i Horten den 20.-21. september. AudioAktøren har gleden av å vise frem denne unike...
Bil-Stereo på HiFi messen i Horten
