Dette har vi ventet på temmelig lenge, og endelig er den klar. LUMIN P1 er klar for levering i desember - i sort eller sølv.
Prisen er 98.000,-
Her har man alt av innganger - til og med 3xHDMI + 1 HDMI UT slik at man fint kan koble til en Apple TV o.l
Lineær strømforskyning.
LUMIN P1
Our most flexible player yet, LUMIN P1 is designed to sit right in the heart of your audio system.
Use as a streamer, a DAC, a pre-amplifier or all three!
Main features
LUMIN P1 makes system integration easier than ever:
9 digital & analogue inputs
USB
New Remote Control
A new tactile infrared remote control allows easy change of input, volume adjustment, playlist navigation and more.
The exceptionally well-constructed acrylic and zinc LUMIN remote is made in Austria and is enirely Roon Ready.
The new infrared receiver built in to LUMIN P1 is compatible with universal remote controls, phones and automation systems.
Flexible setup options
IDEA 1 - STREAMING DAC
LUMIN P1 can be used like all other LUMIN players. With its DSD512/PCM384 support, Femto Clock System, Fibre Networking, toroidal power supply, and Leedh Processing, P1 is second only to LUMIN X1 in pure streaming ability.
IDEA 2 - HI-FI HUB
Connect all your stereo sources to LUMIN P1 and attach a power amplifier and you've got everything you need for an incredible music system.
IDEA 3 - 2-CHANNEL TV SYSTEM
No need for an AV Receiver. Simply attach your HDMI sources to LUMIN P1 and P1 to your TV. With HDMI ARC, all your audio comes through your main speakers.
P1 SPECIFICATION HIGHLIGHTS
Tom Egil Johnsen
47 83 29 22
tom@endpointaudio.no
Prisen er 98.000,-
LUMIN P1
Main features
- 9 digital & analogue inputs
- USB Digital Audio input & output support up to Native DSD512
- Balanced & unbalanced analogue inputs
- SPDIF & AES input support up to 192/24 with DoP
- HDMI 2.0 inputs & 4K passthrough with ARC support
- New processor delivers native DSD512 & PCM384 playback
- Dual Mono design throughout maximises channel separation
- Dual ES9028PRO SABRE DACs in Mono mode
- Femto Clock System with precision FPGA distribution
- New integrated dual-toroidal linear power supply & all-in-one chassis
- Fibre Network provides complete isolation from network digital noise
- Leedh Processing lossless volume control
USB
- Industry-leading XMOS USB audio controller
- Native DSD512 and PCM384 compatible
- Windows 10 & Mac OS compatibility
- Balanced and Unbalanced analogue input
- LEEDH volume processing
- Passthrough function for home cinema integration
- DoP64 / 192 kHz 24-bit compatible
- TOSLINK, SPDIF (RCA), AES inputs
- HDMI 2.0 Specification compatible
- Supports 2.0 PCM audio decoding
- HDR, Dolby Vision, Dolby Atmos, DTS passthrough
- ARC compatible output
New Remote Control
IDEA 2 - HI-FI HUB
- NETWORK PLAYBACK:
- Up to DSD512
- Up to 384 kHz, 16–32-bit, Stereo
- MQA Full Decoding
- UPSAMPLING RATES & BIT DEPTHS:
- DSD128 upsampling option for all files
- PCM 384kHz upsampling option for all files
- DIGITAL INPUT:
- USB:
- USB Audio Class 2 Compatible
- WINDOWS 10 (Release 1703 or above) / Mac OSX or above
- DoP 128 support
- PCM 44.1–384 kHz, 16–32-bit, Stereo
- AES/OPTICAL/SPDIF:
- PCM 44.1 kHz–192 kHz, 16–24-bit
- DSD64 (DoP64, DSD over PCM)
- HDMI X3:
- PCM 2.0 Audio support
- 4K Video Passthrough
- USB:
- DIGITAL OUTPUT:
- USB:
- Native DSD512 support
- BNC SPDIF:
- HDMI X1 HDMI PASSTHROUGH AND ARC SUPPORT)
- ARC (Audio Return Channel) support
- USB:
- ANALOGUE INPUT:
- RCA Unbalanced x1
- XLR Balanced x1
- ANALOG OUTPUT:
- Dual ESS SABRE32 ES9028Pro DAC chips
- Fully balanced layout with high-quality components
- Output connectors coupled with dual LUNDAHL LL7401 output transformers
- OPTICAL NETWORK:
- Industry-standard SFP
- 1000Base-T Gigabit Ethernet
- Adapter may be needed for your particular switch/cables
- Use simultaneously with RJ45 (e.g. connect one to router and one to LUMIN L1 or NAS)
- POWER SUPPLY:
- Internal dual-toroidal
- Separate digital & analogue circuitry
- Low-noise linear regulator
- PHYSICAL:
- FINISH:
- Black anodised aluminium
- Raw aluminium
- LUMIN (SOLID ALUMINIUM CHASSIS):
- 350mm (W), 380mm (D), 107mm (H), 12kg
- FINISH:
Tom Egil Johnsen
47 83 29 22
