Ny Cary hodetelefon forsterker...!
ardilla
OSLO
Det er to versjoner. En Hybrid med rør og en ren transistor.
CDWMcInSpots
Bergensregionen
Audio Electronics by Cary Audio Nighthawk Headphone Amplifier
Denne tråden handler altså om Nighthawk Headphone Amplifier fra produsenten/merket Audio Electronics by Cary Audio:
NIGHTHAWK
Headphone Amplifier
The Nighthawk Headphone Amplifier is an all solid-state design, based on a new monolithic JFET device with exceptional sonic qualities. The combination of a well-designed front end and this Class A discrete complementary output stage yields tremendous speed and bandwidth for very accurate musical reproduction.
The power supply is again designed with very low noise and over-spec’d parts to be optimized for superb audio performance. All internal components of the Nighthawk Headphone Amplifier are thus optimized to maximize sonic potential and exhibit Audio Electronics sonic signature, which does not sound like typical solid-state equipment.
Specifications
Input Impedance
50 Kohms
Gain
20dB
Frequency Response
5Hz to 35 kHz (-1dB)
Signal to Noise Ratio
>90dB at 0dB gain
THD
<0.01%
Channel Separation
>70dB/10kHz
Output Power
400mW/300 Ohms
600mW/30 Ohms
Output Impedance
5 ohms
Full Regulated Power Supply
Discreet regulators for audio circuits
Connectors (audio)
1 x phone jack
4 x gold plated RCA connectors
1 set for input and other used as pass thru
Dimensions
14.5" L X 8.5" W X 4" H
Weight
10 lbs.
Informasjon
Introducing Audio Electronics by Cary Audio!
Cary Audio has a long history of providing the high-end community true audiophile sound quality with its award winning line of tube and solid state amplification and digital products for audio and cinema systems. Through Audio Electronics, Cary Audio’s subsidiary originally created in 1993 and now re-launched, a new segment of music lovers is about to be wowed. While Cary Audio has an established reputation with the seasoned audiophile, Audio Electronics is positioned to reach a new generation of music fans with a smaller, sleeker design suited for the urban environment.
By providing a modern design and excellent sound quality in lower price-point products, Audio Electronics is promoting the future of the high-performance audio industry while preserving the heritage and integrity of the Cary Audio brand. Audio Electronics products will be available through this online store or at Cary Audio dealers.
ardilla
OSLO
De viste den fram to versjoner på CES 2012
Men det er jo ikke Audio Electronics - dette er Cary under eget hoved-navn. Skjønner ikke hvorfor de gidder styre med to "brands". Audio Electronics skal liksom være budsjett-merket.
Så da er det altså Nighthawk + de to nedenfor. Alt fra Cary men den ene er fra Audio Electronics som er Cary likevel.
http://www.caryaudio.com/pdfs/2012 CES Show Report.pdf
Solid state: SH-1
Tube Hybrid HH-1
CES-report 2012:
A second system in the room featured headphone listening using AKG K702 Reference
Headphones through a choice of our CAD-300SEI single-ended triode tube integrated amplifier,
our new HH-1 hybrid tube headphone amplifier, or SH-1 solid-state headphone amplifier. The
music was sourced from our MS-1 music server played through our Xciter DAC.
The new headphone amplifiers are the first products in a new series of smaller electronics, yet still with the full range of Cary Audio sound and quality. The two high performance headphone amplifiers were shown for the first time at the 2012 CES, one solid-state and one hybrid tube/Mosfet. Both models are brand new designs featuring low output impedance and high current capability, allowing them to drive the most difficult headphones with ease.
