Noen som kjenner til denne?
motoren
Flekkefjord
Noen som kjenner til denne?ligger stadig på Finn.no og ser litt spennende ut.
[h=2]Beskrivelse[/h]SPH-D311
High-End platespiller
Base: MDF, nice coated, 42*39.5*45 CM, 6KG
Platter: acrylics, frosting finish, 30(dimension)*4.3(thickness) CM, 3.5KG
Bearing: #304 stainless steel for bearing, phosphor bronze for bearing house
Stand: alloy aluminium in oxidation finish
Tonearm: 9", effective length 230 MM; aluminium base, pipe, headshell, stainless steel counterweightand lift; height adjusting: 0~6 MM
Drive: belt drive
Electronic specification:
Speed: 33 1/3, 45 rpm
Speed Accuracy: 0.5%
Wow & Flutter: ±0.07 %
SNR:>71dB
Cartridge: MM
Motor: external built motor with standard measure to fix the correct position between motor andturntable; Premotec DC motor from the Netherlands, loading torque 10MNM, power rating: 5W, as coredriven source;
Tonearm: overhang 22 MM, cartridge weight: 4~10 g
(Power) Input: DC15V 1A
Power Consumption: 24 W
Cartridge specification:
Response Frequency: 20Hz-20kHz±3dB
Channel Separntion: 20dB
Channel balance?2.0dB
Cartridge Pressure: 1.5?2.0g
Sensibility: 5mV±2dB
Gross
