U
utgatt19288
Denne ble nettverksspilleren fra T+A ble vist på Puls 2008 messa i høst. MP 1250 R
En feature som var litt morsomt var at man kunne bruke en USB memory-stick. Mener husker spilleren var priset rundt ca 25k
The back panel of the MP 1250 R shows the enormous potential of this machine: it not only features High-End analogue outputs, but also a jitter-free digital output. Two high-quality digital inputs (coax and optical) are available for converting external sources (e.g. set-top boxes), so that they can also exploit the superb sound qualities of the MP 1250 R just like the LAN, W-LAN, iPod and USB ports. The MP 1250 R can be remotely controlled like any other source device, i.e. via the master unit of the R-system, and is connected using the R-Link data bus socket. An RS 232 socket is available for updates.
Main circuit board with input switching for network and digital sources. Socket for optional modules.
Streaming Client (SCL) provides the connection to Internet radio, all network sources, iPOD and USB sources.
High-End analogue output section and converter circuit board, of symmetrical construction with completely separate channels. Double differential converters with signal processor, and the famous switchable oversampling algorithms of the R-player.
High-performance mains power supply with sophisticated voltage stabilisation measures.
Fully graphic-capable VFD screen for displaying all machine states and functions. Most of the MUSIC PLAYER functions can be controlled from the front panel.
