Da fortsetter 100 års-festen med gode tilbud!
Vi er også stolt av vår nye nettside! http://www.mus-mag.no
Vi holder på å oppdatere den slik at flest mulig produkter ligger på den...
Fra EC sine hjemmesider:
"...ECC-1
Product of the year 2008-2009
The ECC-1 is the new entry-level CD-player for classic line. Modern production technology has been utilized to keep the manufacturing cost at a minimum and give a performance that will rival the best. The latest 24bit/192kHz DAC from Cirrus Logic, together with a precision fully balanced analogue output stage operating in class A, sets the basis for a detailed, delicate and dynamic sound
The latest 24bit/192kHz DAC from Cirrus Logic, together with a precision fully balanced analogue output stage operating in class A, sets the basis for a detailed, delicate and dynamic sound. A damping platform based on the EMC1 UP anti-vibration system has been developed to create the best possible working conditions for the laser pick-up.
The ECC 1 features both balanced and single-ended outputs, and a coaxial digital output. The analogue output filter is optimized to reduce the phase shift at higher frequencies, thereby leaving the high frequency music information..."
For mer info på Electrocompaniets ECC1 besøker du http://www.electrocompaniet.com
For info på Audiopro produktene besøker du http://www.audiopro.com
Vi gjør oppmerksom på at ECC1 tilbudet varer frem tom. mandag 20.09.10
Med forbehold om trykkfeil! 100 kroners tilbud fås desverre kun ved personlig oppmøte i butikk...
For spørsmål kan dere ringe 55908530 eller maile oss på info@mus-mag.no
Vennlig hilsen
Musik-Magazinet
"...ECC-1
Vennlig hilsen
Musik-Magazinet
