Lumin Nettverksspillere på lager. Kan leveres innpakket i julepapir!
Vi har nå Lumin på lager! Dette er plug and play med markedets beste app for styring og oversikt.
Vi har på lager
A1 - 69.990,-
T1 - 39.990,-
D1 - 19.990,-
M1 - 19.900,- (Nettverksspiller med forsterker) 2x60W
U1 - 64.990,- High end streamer uten DAC.
L1 - Server 2TB - 9.900,-
[h=2]Specification for all LUMIN Music Players[/h]
  • [h=3]Streaming Protocol:[/h]
    • UPnP AV protocol with audio streaming extension
    • Gapless Playback
    • On-Device Playlist
  • [h=3]Supported Audio File Formats:[/h]
    • [h=4]DSD Lossless:[/h]
      • DSF (DSD), DIFF (DSD), DoP (DSD)
    • [h=4]PCM Lossless:[/h]
      • FLAC, Apple Lossless (ALAC), WAV, AIFF
    • [h=4]Compressed (lossy) Audio:[/h]
      • MP3, AAC (in M4A container)
  • [h=3]Supported Audio Sample Rates, Bit Depths, Number of Channels:[/h]
    • PCM, 44.1kHz - 384kHz, 16 - 32bit, Stereo
    • DSD, 2.8MHz, 1bit, Stereo (5.6MHz on LUMIN S1)
  • [h=3]Upsampling rates & bit depths:[/h]
    • DSD upsampling option for all files up to 96kHz
  • [h=3]Supported Control Devices:[/h]
    • All models of Apple iPad (v2 or later). iOS 5.0 or later required. Full Retina Display support.
  • [h=3]App Features:[/h]
    • High-resolution artwork. Artwork caching. AirPlay compatibility. Multiple-tag handling. ‘Composer’ tag support. Find & Filter. Tag browsing.
  • [h=3]Input:[/h]
    • Ethernet network 100Base-T
    • USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
  • [h=3]Outputs:[/h]
    • [h=4]Analog Audio:[/h]
      • XLR balanced, 4Vrms, pin 2 Hot
      • RCA unbalanced, 2Vrms
    • [h=4]Digital Audio:[/h]
      • [h=5]BNC SPDIF:[/h]
        • PCM 44.1kHz–192kHz, 16–24bit
        • DSD (DoP, DSD over PCM) 2.8MHz, 1bit
  • [h=3]Finish:[/h]
      • Raw brushed aluminium
      • Black anodised aluminium finish is available as a special order item. Please contact your retailer for costs and lead time
  • [h=3]Other:[/h]
    • Firmware-upgradable for further features and enhancements
    [h=6][/h]
Tom Egil
47832922
tom@endpoint-audio.com
Endpoint Audio
Endpoint Audio sine annonser
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
Lockwood Loudspeakers - Endpoint Audio
  • 12
Endpoint Audio presenterer: Lockwood Loudspeakers – Et legendarisk britisk merke gjenfødt for ekte audiophile. For halvannet år siden – i mai 2024 – sto vi klare til å lansere Lockwood...
J.Sikora Aspire.
J.Sikora Aspire.
  • 2
Nyhet: J. Sikora Aspire – Den nye inngangsporten til high-end vinyllyd! Vi har spennende nyheter fra den polske high-end produsenten J. Sikora. Selskapet, grunnlagt av Janusz Sikora, har...
Lampizator Aphrodite - Lampizators nye flaggskip.
  • 5
Lampizator fortsetter å pushe grenser og jobber hele tiden med å sette en ny standard for industrien. Lampizator leverer DAC’er fra 65.000,- og oppover. Av alt jeg har hatt så er det lite som...
Canor Virtus A3
Canor Virtus A3
  • 1
Canors nye kreasjon Virtus A3 begynner å få flotte tester i hifi verdenen. LP International har tatt A3 under lupen og sett på hva som befinner seg under lokket. Dette er en alt i ett forsterker...
Flott test av den nye Canor A3 i Hifi Pig!
  • 2
Canor, en slovakisk produsent med 30 års erfaring i å lage høykvalitets HiFi-komponenter, har markert seg som en aktør å regne med i lydverdenen. Deres nyeste kreasjon, Canor Virtus A3, er en...
