LH Labs har en rekke spennende produkter som starter med små USB DAC/Hodetelefonforsterker-løsninger, opp til deres største! DAC - Light Harmonic DaVinci Sire.
Pulse Modellene har spesifikasjoner man må opp i vesentlig dyrere produkter for å finne, og her får man både en DAC og en Hodetelefonforsterker i en og samme pakke.
Her presenteres Geek Pulse modellene:
Geek Pulse.
Geek Pulse is the world's most powerful 32/384 kHz + DSD128 desktop DAC and 3000 mW headphone amplifier. When it comes to the Geek Pulse family, this is what others might call a base model. We prefer to think of it as where awesome starts.
Geek Pulse X.
This is a fully-balanced, dual mono version of Pulse, a 32/384 kHz + DSD128 desktop DAC and 3000 mW headphone amplifier. There's a 1/4" stereo headphone jack and a four-pin balanced headphone jack. On the back, there's a pair of balanced XLR outputs along with a pair of RCA outs.
Geek Pulse Xfi
Like Pulse X, this is a fully-balanced, dual mono version of Pulse, our 32/384 kHz + DSD128 desktop DAC and 3000 mW headphone amplifier. The difference, though, is that this one is on steroids. It features two femto clocks and fully-upgraded active and passive components.
Specs!
I tillegg leveres også powersupply til enhetene.
LPS - Linear Power Supply
LPS takes dirty AC power from the wall and delivers clean DC power to Pulse. This clean DC power has very low noise, which improves the sonic quality of the music coming out of Pulse. With clean power, you get more natural music.
As an added feature, LPS can be used to clean the noise off of the USB connection from your computer to Pulse. Just connect your computer to LPS using a USB cable, then connect LPS to Pulse using a second USB Cable. When you do this, LPS disconnects the 5V power coming over the USB cable from the computer and replaces it with clean (under 6uV noise) 5V power coming from its super-regulated power circuits.
Pulse - 12.500,-
Pulse X. - 15.500,-
Pulse Xfi - 25.500,-
LPS. - 6.990,-
tom@endpoint-audio.com
47832922
Geek Pulse.
Geek Pulse X.
Geek Pulse Xfi
Specs!
- USB Audio Class 2.0 input with other 4 digital audio inputs all converted to 3L buffered I2S signal, then send to dual DAC IC
- Dual mono full balanced current output, then transconductance amp, summing up output amplifier
- Dual mono full balanced current output then transconductance amp then analog filter with output amplifier
- Two audiophile grade low jitter TCXO with super quiet power circuit and mu-metal shield
- DAC IC: Two ESS9018K2M
- Digital Inputs:
- One USB 2.0 Type B Female
- One set SPDIF via TOSLINK (JIS F05 Female)
- One set AES/EBU (AES/EBU input compatible SPDIF signal by Adapter)
- Two set SPDIF via RCA Coaxial
- Supported Native PCM format: 44.1, 48, 88.2, 96, 176.4, 192, 352.8K, 384 kHz in 16/24/32 bit
- Supported Native DSD format: 2.822, 3.072, 5.644, 6.144 Mega Hz / 1bit (via USB 2.0 Input) Support both DoP standard 1.1 and Native DSD (requires ASIO driver)
- Patent Pending: 3L buffer by Light Harmonic Dual loop re-clock for all digital audio inputs
- Digital Filter: Two mode selectable: Time Comprehension Mode (TCM) and Frequency Response Mode (FRM)
- Line Output Configuration:
- One pair balanced via XLR (pin 2 hot),
- One pair Single-ended via gold plated Switchcraft RCA
- Single-ended output voltage and impedance: 2.1Vrms (47 Ohm)
- Balanced Output: 4.2Vrms (47 *2 Ohm)
- Headphone output configuration: Balanced XLR 4 Pin Female Jack (Neutrik) Single-end via 1/4" TRS Headphone Jack
- HP Balanced output voltage and impedance: 3.5V / 6V / 13.8V switchable (0.9 Ohm flat in 20~20K Hz range) via dual mono headphone output amplifier
- HP Single- ended output voltage and impedance: 1.8V / 3V / 6.8V switchable (0.47Ohm flat in 20~20K Hz range)
- THD+N: Better than 0.003%
- SNR: Better than 116dB
- Frequency Response: 1-50K (-3dB) control by Bessel analog filter
- Power Input: 12V DC - 650mA ~ 950mA depend on system load and sampling rate
Pulse - 12.500,-
Pulse X. - 15.500,-
LPS. - 6.990,-
47832922
