Rørutstyr KT120
Audiomix
Jeg har sett en del forsterkere med KT120 (Russisk Tung Sol) som har havarert.
I det siste har jeg hatt litt utveksling med Audio Research.
Her er advarsel som gjelder et par AR forsterkere.
Hi Hans:
KT120s are a no no in the VT100: The horizontal mounting causes the poorly-supported KT120 plate structure to sag inside the tube which can lead to early failure. Also, the extra weight of the KT120s causes them to sag and lose contact with the sockets –which as you know --can cause catastrophic failures! Further, the higher heater current requirement of the KT120 will make the power transformer run hotter and may possibly shorten its service life. Stick with 6550s.
The REF210 requires a now-discontinued factory mod to enable the use of KT120s. KT120s will NOT WORK without the mod and will damage the REF210! Since the mod. was discontinued, we recommend the owner stick to 6550s. And, before the customer asks –NO, we will not install the mod. It has been retired.
Best regards,
Chris Ossanna
Hi Hans:
FYI, we do try to offer updates for a few years. But after demand falls off for a particular update, we no longer stock the parts required. You would laugh if I told you how many people I have to turn away wanting updates we discontinued over 20 years ago J These folks must think we have a parts stock room the size of the US government warehouse where the Ark of the Covenant disappeared into at the end of “Raiders of the Lost Ark”…
Chris
Jeg vil si at det er svært risikabelt å benytte KT120 i forsterkere som ikke er konstruert for disse.
Selv om forsterkerprodusenten sier at de kan benyttes som alternativ til de originale vil jeg si som Chris Ossanna hos Audio Research:
"Stick with 6550's"
Mange mener at KT120 gir mer power eller høyere effekt enn f.eks. 6550.
Det er feil. Strømforsyningen bestemmer hvor mye forsterkeren kan yte.
Hvis det er noen forskjell er den i alle fall marginal og langt fra hørbar.
JK
Jeg har selv en REF210 som har "Factory mod." til å bruke KT120, og en ser at det er montert inn en del ekstra komponenter. Fint at dette blir opplyst om da det er mange rykter på nettet hva som kan brukes og ikke...
Når det gjelder forskjeller på KT120 vs 6550 så blir det meldt om bedre lyd og friskere spillestil med KT120, men er ikke mye til hjelp visst forsterkeren havarerer....
marius markusen
oslo
Hei takk for tipset.
Har arc vt 100 mk III som jeg lurte på å sette inn kt 120 den dagen 6550 røra har gjort jobben.
Men da tror jeg at jeg holder meg til 6550.
Mvh Markusen
svartkeiko
9395 KALDFARNES
KT 120 gir neppe mer Power/effekt men et litt annerledes lydbilde.Bassen blir mer definert i min VS 115 og bare det gir en lydmessig gevinst.Jeg blei anbefalt å bruke
KT 120 i min VS 115 så jeg har ikke noen umiddelbare planer på å gå over til 6550 igjen.Det som er viktig med disse rør-bytter er jo også at de er matchede rør.
Rørene er montert loddrett i min VS 115 men med en forsterker som har disse KT 120 i vannrett posisjon hadde jeg vært svært i tvil.Det er fint at noen forteller om sin
erfaring rundt dette.
Mvh Kenneth
