Hvis du kan bygge selv, synes jeg dette kitet ser lovende ut.
Kan kon.fig til unity-gain altså som buffer og ville brukt den mellom kilde og forsterker.
FEATURES -
- Class-A tube amplification with single-ended (SE) mosfet output stage.
The mosfet output provides a very low impedance signal resulting in exceptional bass performance. Driving long interconnect cables is not a problem with this design.
- Servo circuit nulls all DC offset voltage.
This new circuit eliminates all dc offset so large coupling caps on the output (a major source of sonic degradation) aren't necessary.
- 3 selectable gain settings.
A linestage doesn't require much amplification these days so CATO has been optimized to operate between unity and 10dB of gain. A handy switch let's you choose between 3 different gain settings.
- Compact Low Noise Power Supply
CATO's power supply features encapsulated Toroidal transformers, Schottky diodes and AC filaments all mounted on an easy to assemble printed circuit board.
- Stylish Hardwood Chassis
Tigris hardwood chassis accented with Ebony corners that function as feet.
