Kjøpe lox over disk?
O J
Gidder noen bare å fortelle meg at dette selvsagt er noe jeg bare kan glemme her hjemme i potetlandet?
Klippet fra et annet forum:
Re: Value of a very small liquid (turbine) rocket engine?
That is why I suggested a medical supply store. They normally sell a few liters of LOX for oxygen breathing machines. :eek: It should not be that difficult to obtain smaller quantities of LOX. It is just cheaper in the larger quantities. In the US, there are DOT(Department of Transportation) approved tanks for LOX transport and storage, I'm sure the same exists in Norway.
A heat exchanger or condenser/evaporator that will lower GOX to LOX temperatures is not a simple setup. I haven't built one but I would imagine that in order to set one up, you'd spend more money than if you went out and purchased the LOX from a medical supply store.
Lox (liquid oxygen) = minus 183 grader..
O J
Fenalaar skrev:
Lurer på hva i helsikke du skal med LOX? ???
Var jeg som lurte på hva en bitteliten lox turbin kunne være verdt :)
(Skjønner at en ikke bare kan bygge en uten å først løse et par problemer, som jeg tror jeg kan ha en løsning på)
O J
Ringte Air Liquide. De hadde flytende nitrogen, cryotank, og oksygen(under trykk).
Kommer vel på rundt 10.000,- alt sammen. Ganske så aktuelt. Tusen takk for tipset !
