Kun via Endpoint Audio og godkjente forhandlere.
Acoustical Systems leverer allerede markedets mest nøyaktige protraktor for å sette opp din platespiller perfekt. Sammen med Analogmagik og Acoustical Systems har du nå muligheten til å fintune hele oppsettet og få analoglyden så perfekt som det lar seg gjøre.
Analogmagik leverer en pakke med programvare og testplater som lar deg måle alle parametre i prosessen.
vi har 3 kalibreringspakker hvor vi har satt sammen Analogmagik + Acoustical Systems sine løsninger!
Pakke 1:
Acoustical Systems Smartractor (4995,-) + Smartstylus (1195,-) + USB Lydkort anbefalt av Analogmagik (1300,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 14.990,-
Pakkepris 13.000,-
Pakke 2:
Acoustical Systems Smartractor (4995,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 12.495,-
Pakkepris 11.200,-
Pakke 3:
Totalpris 8.800,-
Pakkepris 8000,-
What is AnalogMagik ?
AnalogMagik is a Windows based turntable cartridge calibration software designed by Richard H. Mak and a team of engineers. It offers a scientific and repeatable method of calibrating every cartridge setup parameter, including:
Turntable Speed
Azimuth
Vertical Tracking Angle / Stylus Raking Angle
Anti-Skating
Optimizing Phono Stage Loading
Optimizing Phono Stage Gain Setting
Vertical Tracking Force
Measuring Vibrations
Determining Resonance Frequencies
AES Wow & Flutter
After you have performed a basic alignment on your turntable's cartridge using an appropriate alignment tractor, our software and Test LPs will help you optimize and fine-tune all the above setup parameters to achieve a more accurate analog cartridge setup.
Simply follow the onscreen instructions, and the program will guide you through all the test functions. It will also tell you what "optimal" numbers to look for, and what cartridge adjustments you need to make to get there.
https://youtu.be/O1CBS5CfRtI
Sjekk ut https://www.analogmagik.com/ og alle tutorials på siden for å få et bilde av hva dette er.
Her ser vi tydelig hvor nøyaktig Acoustical Systems protraktor er!
Tom Egil
Pakke 1:
Pakkepris 13.000,-
Pakke 2:
Pakkepris 11.200,-
Pakke 3:
Totalpris 8.800,-
Pakkepris 8000,-
Turntable Speed
Azimuth
Anti-Skating
AES Wow & Flutter
Tom Egil
