J. Sikora Reference - 1 av 5 med A+ rating i Stereophile.
J. Sikora har høstet en mengde "best of" priser og igjen er Reference modellen (47.000 USD) ranket blant de 5 beste som er på markedet.
Også tonearmen KV12 VTA (9995 USD) er ranket med A+ av Stereophile.
Våre Priser:
Reference - 365.000,-
KV12 VTA - 85.000,-
A+
J.Sikora Reference: $47,000 w/o tonearm
This Polish company's top-of-the-line turntable is a nonsuspended, high-mass design, weighing 253lb. The dynamically and statically balanced platter alone weighs 40lb! Drive is with four square belts spun by four Papst DC motors. MF found that the plinth was immune to knuckle raps and motor start-up noises and wrote that the Reference was very quiet. He decided that this J.Sikora 'table had been superbly tuned to extract deep, well-controlled bass free of overhang or excess. The measured speed accuracy was impressive, as was its isolation from the outside world. Using J.Sikora's own KV12 VTA tonearm ($8995) as well as SAT and Kuzma tonearms, MF couldn't find fault with any aspect of the Reference's sonic performance or its machining and physical presentation. He summed up: "For those willing to make the expenditure, add the J.Sikora Reference to the list of great mass-loaded turntables at this price."(Vol.45 No.7 WWW)
FA23A36C-EBD0-48EB-985D-69869F353DA3.jpeg 4024A8AE-8A8A-41B6-B6C9-15530B23FF37.jpeg 793CF32A-075C-42DC-9329-92B8D6F59043.jpeg
Tom Egil
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
EMT 928 II - Stereophile Klasse A Platespiller, Høst 2024
Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile. "EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black...
