J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm.
Michael Fremer hos Stereophile har testet J.Sikora Reference
EVERYTHING ABOUT THE J.SIKORA REFERENCE—ITS WELL-TUNED DESIGN AND CONSTRUCTION, ITS OUTSTANDING INSTRUCTION MANUAL, ITS FINE POWER SUPPLY AND 40LB, MULTIMATERIAL PLATTER, AND OF COURSE THE SOUND MAKE IT A ”MUST AUDITION” TURNTABLE AT AND WELL ABOVE ITS PRICE.
The Reference turntable is an extreme development towards the same goals we set for the Standard turntable. This is a no-compromise turntable that can be considered a true reference in both name and performance.
No less than six types of materials and four centrally-controlled DC/PAPST motors are used. The platter is both dynamically and statically balanced and is constructed from three separate materials. The main bearing was improved with the use of steel, cemented carbides and zirconium. There is an option to use up to three tonearms, and again a wide variety of arms can be accommodated.
313415370_605728531350472_6687045388294043222_n-300x213.jpg 321090762_705542094270913_2184292521041829490_n-300x294.jpg 339120125_174373888818745_4144143427375779344_n-234x300.jpg 376808341_797361978853792_2115175785643163490_n-235x300.jpg
Recommended Components Fall 2024 Edition Turntables
Turntables:
A+:
J.Sikora Reference: $48,000 w/o tonearm
This Polish company’s top-of-the-line turntable is a nonsuspended, high-mass design, weighing 253lb. The dynamically and statically balanced platter alone weighs 40lb! Drive is with four square belts spun by four Papst DC motors. MF found that the plinth was immune to knuckle raps and motor start-up noises and wrote that the Reference was very quiet. He decided that this J.Sikora ’table had been superbly tuned to extract deep, well-controlled bass free of overhang or excess. The measured speed accuracy was impressive, as was its isolation from the outside world. Using J.Sikora’s own KV12 VTA tonearm ($8995) as well as SAT and Kuzma tonearms, MF couldn’t find fault with any aspect of the Reference’s sonic performance or its machining and physical presentation. He summed up: “For those willing to make the expenditure, add the J.Sikora Reference to the list of great mass-loaded turntables at this price.”
Endpoint Audio
Endpoint Audio sine annonser
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
Lockwood Loudspeakers - Endpoint Audio
  • 12
Endpoint Audio presenterer: Lockwood Loudspeakers – Et legendarisk britisk merke gjenfødt for ekte audiophile. For halvannet år siden – i mai 2024 – sto vi klare til å lansere Lockwood...
J.Sikora Aspire.
J.Sikora Aspire.
  • 2
Nyhet: J. Sikora Aspire – Den nye inngangsporten til high-end vinyllyd! Vi har spennende nyheter fra den polske high-end produsenten J. Sikora. Selskapet, grunnlagt av Janusz Sikora, har...
Lampizator Aphrodite - Lampizators nye flaggskip.
  • 5
Lampizator fortsetter å pushe grenser og jobber hele tiden med å sette en ny standard for industrien. Lampizator leverer DAC’er fra 65.000,- og oppover. Av alt jeg har hatt så er det lite som...
Canor Virtus A3
Canor Virtus A3
  • 1
Canors nye kreasjon Virtus A3 begynner å få flotte tester i hifi verdenen. LP International har tatt A3 under lupen og sett på hva som befinner seg under lokket. Dette er en alt i ett forsterker...
