Ny og forbedret utgave av den populære hip-dac fra iFi Audio! Kun kr 2 145,-
Specifications:
Formats supported | DSD PCM DXD MQA | 256/128/64, Quad/Double/Single-Speed 384/352.8/192/176.4/96/88.2/48/44.1kHz 384/352.8kHz 384/352.8kHz |
Digital Inputs | USB 3.0 Type 'A' (USB2.0 compatible) | |
Headphone Outputs | Balanced S-Balanced (S-E) | 4.4mm 3.5mm |
Power Output (@1% THD) | Balanced S-Balanced (S-E) | 400mW@32Ω; 6.3V@600Ω 280mW@32Ω; 3.2V@600Ω |
Battery | Lithium-polymer 2200mAh | Approx. 8 hours |
Power System | Charging via USB-C, BC V1.2 compliant up to 1000mA charging current and 6.3 volts | |
Power (max) | <2W idle, 4W max | |
Dimensions | 102 x 70 x 14mm 4.0" x 2.8" x 0.6" | |
Weight | 125g (0.28 lbs) |
hip-dac2 review by Berkhan of Headfonia
“The hip-dac 2 has excellent imaging as well, which is better than the original version. And it is combined with good transparency, especially in mids. Presentation-wise I think the device is mid-centric just as the first version. The tonality in the instruments is very satisfying and you have a good body in the whole sound.
So I liked the sound performance and I think it’s better than what hip-dac has to offer. The difference is not huge, but definitely meaningful according to my tests.”
Berkhan - Headfonia
(Click name to read original review)
iFi Audio GO blu! Kr 2 295,- Et lite stykke ingeniørkunst! Hvordan få noe så lite til å høres så bra ut? Spør iFi Audio. De gjør det hele tiden...
Specifications:
Chipset | DAC Bluetooth | Cirrus Logic CS43131 Qualcomm QCC 5100 |
Inputs | Wireless Wired | Bluetooth 5.1 ( AAC, SBC, aptX, aptX HD, aptX Adaptive, aptX LL, LDAC, LHDC/HWA Codec) USB-C (24/96) |
Headphone Outputs | Balanced SE | 4.4mm 3.5mm |
Power Output | Balanced SE | 245mW @ 32Ω; 5.6v @ 600Ω 165mW @ 32Ω; 2.8v @ 600Ω |
Output Impedance | Balanced SE | <1Ω <1Ω |
SNR | Balanced SE | 111dB(A) @ 0dBFS 116.5dB(A) @ 0dBFS |
DNR | Balanced/SE | >120dB(A) |
THD + N | Balanced SE | <0.009% @ (6.5mW/2.0v@600Ω) <0.03% @ (100mW/1.27v@16Ω) |
Frequency Response | 20Hz - 45kHz (-3dB) | |
Battery | Lithium-polymer 450mAh approx. ~8 hours (depending upon volume and headphones) | |
Dimensions | 54 x 34 x 13 mm 2.1' x 1.3' x 0.5' | |
Weight | 27g (0.95 oz) |
iFi audio GO blu review by Louis Gonzalez
“The GO blu to me is a piece of gear that you purchase for a particular function and then find out you like it more whilst performing other functions. Versatility is off the charts for many different scenarios.
The GO blu can act as a Bluetooth receiver yes, with all the codec capability you could want but it really excels as a micro-DAC dongle, a desktop, or a laptop DAC amp combo and as a sound card replacement. That’s four scenarios in where the GO blu can perform well.”
Louis Gonzalez - Headfonics
Som vanlig kan vi kontaktes på tlf og mail, Terje på tlf: 90762967, mail: terje@audioakt.no og Jon på tlf: 92063085, mail: jon@audioakt.no
Vi tar innbytte, og har finansieringsmuligheter. Ring oss gjerne for å avtale prøvelytting, evt hjemlån av produkter som er av interesse for deg! Kan du ikke komme innom i åpningstiden? Kontakt oss, så avtaler vi en tid som passer deg!
Desemberhilsen fra oss hos:
