G
Gjestemedlem
Den kan jo som man ser på videoen på linken under brukes til å styre f.eks. Windows Media Center, så kanskje dette kan være interessant hvis man vil bruke dette i et multimediaoppsett i stuen?
Nintendo doesn't exactly advertise it, but the remotes for the Wii gaming consoleincluding the balance board that comes with Wii Fithave Bluetooth capabilities. That means you can connect your Wii peripherals to your computer to operate the media center hooked up to your TV, play emulated games with a Nunchuk, Classic Controller, or even a Balance Board, and pretty much have them do anything you can do with a keyboard.
Forresten, MYE annet interessant på Lifehacker.com Vel verdt å adde RSSen derfra.
