Forsterkere Hvor ekte er A-klasse forsterkere
  • Zerostat
    Strømmen
    A21 Signature Line and Integrated Amplifier
    The Sugden pure class A design provides affordable high-end performance from a beautifully engineered single box integrated amplifier. Compact in size with a simple but stylish design, the A21 is possibly the only amplifier you will ever need. With many of the original A21’s still in daily use after fifty years, it could also last a life time. Providing a large soundstage and depth to all types of music, the A21 is an amplifier you can listen to for hours without fatigue. The single ended voltage rail circuit provides impressive dynamics and incredible bass.
    The A21 Signature integrated amplifier is available with or without a MM/MC phono input. Without a phono input it is designated the A21L (line input only). A21aL models can be fitted with a phono input at a later date.
    ​Facilities
    Inputs ​ Five line level (four on A21 Integrated)
    Optional mm/mc phono
    Outputs One pair of stereo multi-way binding posts
    Pre-out (variable), tape out (fixed)
    Remote Control Volume up/down
    Earth terminal
    ​Specifications
    Line Input Sensitivity 170mV for max. out
    Phono Input Sensitivity 3mV/mm, 0.2mV/mc for max. output
    Phono Loading MM 47K MC 100 Ohm
    Power Output 23 Watts into 8 Ohms
    Frequency Response +/-1dB 10Hz-20kHz
    Bandwidth 6Hz-200kHz
    Signal to Noise >83dB
    Gross Weight (packed) 11kgs
    Dimensions 92 x 430 x 350mm (hwd)
    Tipper ut fra andre rene Klasse A forsterkere at Output Power halveres ved 4ohm kontra 8ohm. Dvs ca 11watt. Så da er høyttalermatch viktig. Mine er på 95db og typist 8ohm. Aldri under 4ohm. Burde derfor gå bra.
    Dharmabum
    ​Facilities
    Earth terminal
    ​Specifications
    Grattis med ny forsterker, Sugden suger ikke!
    Balle Clorin
    Denne yter 15 rene klasse A watt hele veien
    MI-10
    stor ja , godt areal med kjøling
    Zerostat
    Strømmen
    Denne har potensiale og blir blir nok stående en stund...
